Author Topic: radial engine cam material choice  (Read 3729 times)
Offline petertha
« on: February 22, 2018, 06:42:59 AM »
I'm mulling over what type of material to use for the cam rings. They need to be hardened. My original plan was O1 (oil hardening) tool steel. Now I'm wondering if I should consider air hardening. I've never used it before, in fact have done very little hardening. Only O1 on simple parts, flame & dunk method.
My understanding of the knife blade crowd is they use air hardening & clamp between 2 aluminum plates to 'quench' after heating in order to minimize distortion of thin blades. My cams are nominal 44mm (1.7") diameter but are kind of swiss-cheesed with holes. I don't have grinding facilities to true them flat if they do any appreciable degree of potato chip curl. Maybe I could tolerate a teeny bit of warpage by stoning but not much. Any feedback or experience?
This link shows similar operation, except he used hardening compound. Maybe so as not to risk quenching distortion?
http://philsradial.blogspot.ca/#!/20...-assembly.html
Offline petertha
Re: radial engine cam material choice
« Reply #1 on: February 22, 2018, 06:45:45 AM »
the cam & some work in progress
Online Vixen
« Reply #2 on: February 22, 2018, 08:38:02 AM »
Case hardening should be adequate for your two cam rings. This will leave the core soft and unhardened and so allow you to flatten out any distortion that may occur.
Offline Ramon Wilson
  • Suffolk in the UK
« Reply #3 on: February 22, 2018, 09:36:13 AM »
Hi Petertha,
I would concur with Mike for case hardening but for another reason that's worth taking into consideration.
Looking at your drawing you have some very thin sections at the periphery which, if you 'through harden' will tend to get much hotter than the thicker areas if flame hardened. Even if done in a controlled environment (ie temp controlled oven) those areas will begin to cool immediately compared to the surrounding areas between oven and quenching. (One way to overcome this is to have a plate either side that is heated at the same time and the whole 'package' is then quenched, the plates helping to keep the temp even.
Even more issues could be experienced with tempering unless done in an oven as those thin areas will cool much quicker giving varying degrees of hardness.
The only thing I would add to either method (through or case) is that when you quench is to keep it as vertical as possible so that it cools as evenly as possible on each side which will help minimise any possible distortion.
Hope that helps a bit more - Tug
Online Vixen
« Reply #4 on: February 22, 2018, 09:46:34 AM »
Tug has a very good point about the thin section of the cam ring. You could consider combining both the inlet cam ring with the exhaust cam ring into a single part to create a thicker overall section.
Where do the cam drive gears fit? Could they also be combined as well?
Online Vixen
« Reply #5 on: February 22, 2018, 10:23:15 AM »
Here are some photos of the cam rings for my 1/4 Bristol Mercury (9 cylinders). I machined the Exhaust cam ring on the outside of the internal gear blank. This was bolted to the combined Inlet cam ring and hub.
Could you combine your gear wheel and cam rings in a similar way?
« Last Edit: February 22, 2018, 01:14:36 PM by Vixen »
« Reply #6 on: February 22, 2018, 12:22:29 PM »
I know it's quite a bit of work posting here, but any change of more pictures from both of you - please ....  :praise2:
Best wishes
Offline petertha
« Reply #7 on: February 22, 2018, 04:03:25 PM »
Excellent feedback thanks. I can obtain this Cherry Red case hardening substance in Canada.
http://www.rosemill.com/v/html/msds/cherry_howto.pdf
Maybe I misinterpreted the procedure originally. It says to quench in oil & I’ve seen others do that. But as suggested, that rapid temperature drop via liquid quench is the problem to be avoided. Which I saw as essentially the same thing as O1. But now I see in the vendors it says “OR LET COOL” meaning no quench, just ambient cooling. I wonder, would ambient cooling yield something less hard, or similar hardness but less penetration, or...?
I guess the easy thing to do is buy some compound, turn up a similar dimensioned washer without the cam profile & just try. Redesigning the now separate inlet/outlet cam plates into a single part is an excellent idea. If I went this route with conventional round stock, would a certain alloy give me a better chance with case hardening? For example 4140 over 1018?
Online Vixen
« Reply #8 on: February 22, 2018, 04:21:59 PM »
Hi petertha,
I am not familiar with those steel grades, we use different steel grades over this side of the pond and almost all of it is imported.
As I understand it, the case hardening material adds a thin layer of extra carbon to the surface layer and so allows the surface (the case) to reach higher levels of hardness. My guess is to avoid 'leaded' free cutting steel and go for more normal 'mild' steel. There must be many members out there who can advise you on which grades case harden better.
Offline Mcgyver
  • Toronto
« Reply #9 on: February 22, 2018, 05:00:24 PM »
They are all quenches in fluid - air, oil, water or the fastest, ice cold brine.  The difference is the speed of the quench.  You could quench W1 in air but it would not harden very much, or you could quench A2 in water and it would harden but with a higher risk of cracks and distortion.  A2 has some big advantages in that an air quench is the least violent so distortion tends to be less that with faster quench.  I would think this has some advantages for tricky looking parts like you've shown.   The disadvantage of A2 is the cost vs say O1, but that's probably of little concern for a single small part
The Cherry Red is afaik much like the old Casenint.  With a few applications, followed by one quench you can get a couple of thou case depth.  Might be enough for a model?  An advantage with casehardening, aside from the ductile core, is that you don't temper, so the outer skin is very hard.  This is often a design advantage, however it will take dent or bruise a lot easier than something through hardened.  If you don't do a rapid quench like oil and just do an air quench, it won't be as hard as it could be - its that rapidly cooling that does the job of locking in the austenite structure that makes it hard.
I could see case hardening or A2 but am sort of like the A2, tempered, in that the case hardening is very thin and won't harden as much with an air quench.
« Last Edit: February 22, 2018, 05:04:50 PM by Mcgyver »
Offline johnl
« Reply #10 on: February 22, 2018, 05:45:01 PM »
FYI. The Hodgson radial engine plans call for 4140 for the cam rings.
Offline petertha
« Reply #11 on: February 22, 2018, 07:42:39 PM »
A2 costs about 43 USD for .125thick x 2" x 18"
A can of the hardening stuff is about half that.
Here are some A2 specs I found.
https://www.hudsontoolsteel.com/technical-data/steelA2
I suspect the size change chart doesn't properly address potential problems with some of my cam plate features like the holes, proximity to edges, non-symmetry etc.
I guess in my thick skull I'm still wondering - if I'm going to heat steel up to cherry red for any of these material options (O1, A1, Steel X, Steel Y with hardening powder...), wouldn't it make sense to use the alloy that yields some increased hardness but with the least amount of quenching temperature reduction shock... which seems to be what air hardening steel is all about? Maybe I'm still missing something here?
I'm still digging around the knife blade forums because I'd think if anyone would be super concerned about warping (= scrapping) a skinny & weirdly shaped part it would be them. I thought maybe I misunderstood the purpose of the ambient temp aluminum clamp plates, sometimes called quench plates. I just assumed it was to minimize distortion during cool down. Other links refer to a slight cooling acceleration affect to tweak hardness. But this link & others like it seems to suggest its more about mitigating distortion.
https://www.bladeforums.com/threads/air-quenching.570302/
Offline Mcgyver
  • Toronto
« Reply #12 on: February 22, 2018, 08:25:13 PM »
I would say yes, and it would be a no brainer.....if not for the excellent points Tug made.   Perhaps A2 sandwiched between a moderate thermal mass (1/8 - 1/4 plate maybe?) is the answer.  Sorry, can't be more certain than that, I don't the experience with such delicate profiles, I'd have to give a try and see how it comes out.
  • Suffolk in the UK
« Reply #13 on: February 22, 2018, 10:56:40 PM »
Hi Petertha
It seems (please correct me if I'm wrong) that you are confusing case hardening steels with through hardening or tool steels. In my experience (work based) you either use one or the other. Though I don't have as much experience with case hardening as I do with through hardening I have never seen such material (tool steels) used for case hardening - If you think about it it defeats the object - the steel is heated in the CH compound - taken to temperature and quenched - you've just through hardened it.
If you are going to case harden then the material should be suitable - eg (in old terms) EN3B or EN32B (you should be able to find comparable steels over there) These are 'mild steels' whose composition is designed to give the right core with a hard surface. Though not usually done they can be tempered but this is not the same as with tool steels if doing this at home by the 'colour' method. Were I to be making this part I would use this kind of material and case harden and leave as hardened.
There are differing ways to achieve the 'skin' - heat the item and roll in the powder then heat again to a good red colour, this can be repeated - the more it's done the thicker the skin though doing it this way that skin will be fairly thin. It can be quenched - preferably in clean cold water either straight from this heating or, allowed to cool, the powder residue cleaned off then the item reheated and quenched. Quenching with case hardening, unlike tool steels is best done rapidly and this is the point at which distortion is likely to occur on thin material. Assuming the item is perfectly heated if it is not truly vertical as it goes in the quench the microscopic difference side to side means one side cooling before the other - 'microscopic' as this may seem this is what will cause the item to bend.
The better way to obtain a decent thickness of skin is to pack the item in the CH powder in a small metal container and heat the entire lot together - the longer at temp the deeper the skin. The powder liquefies so the container needs to be well packed. Quenching should be as above.
Though I often advocate quenching silver steel (drill rod) in oil to avoid cracking I have never heard of quenching CH parts in oil. I see no reason why it shouldn't work but the old CaseNite powder did 'perform' best in cold water.
If on the other hand you decide to make it from through hardening tool steel then the points from my previous post re section thickness should be bore in mind. As said before and as Mcgyver suggests a 1/4" plate either side will help keep the part uniformly heated until quenched. The quenching should be done, not so much rapidly as with CH, but more positively with the accent on that vertical movement with a uniform speed of movement through the oil interface. Most definitely don't - just 'drop it in'
As with all 'new' heat treatments a test piece is a good idea and certainly something I would recommend you do here.
Tug
Offline petertha
« Reply #14 on: February 23, 2018, 01:14:20 AM »
Yes I think I confused matters with my clumsy wording. Thanks for your patience. I guess was trying to say:
1) Oil hardening tool steel, yields through hardening, heat to red hot, liquid quenching = sudden temperature loss = increased propensity for distortion & cracks
2) Air hardening tool steel, yields through hardening, heat to similar red hot, air quenching = slower temperature loss = better for distortion. Possibly over & above improvement by sandwich quench plate method attempting to confine distortion in same plane. This is what I was inferring similarity to the knife blade application.
3) Lower carbon 'regular' steel, case hardening method, heat to similar temp, saturate with powder, allow to air cool. Although it can be liquid quenched according to specs, we are attempting to avoid same problems of 1) & the spec sheet confirms it is OK to air cool to ambient similar to 2). So at least to my amateur eye, the net result looks a lot like 2) other than we only have surface skin hardening.
You have raised one more point which I had not even considered - unequal heating / hot spots based on varying thicknesses of delicate features. But assuming red is +/- red in all cases (I have to confirm the various temps) that will be a common challenge across all 3 metals, no?
I’m only guessing but maybe the designer prescribed those large diameter holes more about achieving a bit of weight savings & maybe a bit of oil splashing. But if they were eliminated, or greatly reduced, would that change your opinion about some of the delicate thin areas along the edge it now presents? Or is it more about the overall aspect ratio disc-like shape?
« Last Edit: February 23, 2018, 01:18:09 AM by petertha »
