Author Topic: sine bar protractor  (Read 3193 times)
Offline sbwhart
  • Live Long and Prosper
sine bar protractor
« on: February 13, 2018, 06:26:30 AM »
I made this sine bar protractor a few weeks ago
To use all you have to do is zero your height gauge on it
Then as the distance between centres is 100mm simply multiply the sine of the desired angle by 100 to give you the height to set the bar to using the height gauge.
Then use it to set up your work piece
Stew
« Last Edit: February 13, 2018, 06:31:00 AM by sbwhart »
Online 10KPete
Re: sine bar protractor
« Reply #1 on: February 13, 2018, 06:38:05 AM »
That's just too handy to be legal.... gonna  have to make one!
Thanks for posting that neat tool.
Offline Andy
  • Hitchin, Herts, Uk
« Reply #2 on: February 13, 2018, 11:12:42 AM »
Interesting device.
 How does the pivot bolt thing work? Clamping or resistant type fit
 Looks like a hex counter sunk bolt with a slot cut in it   :shrug:
« Reply #3 on: February 13, 2018, 11:36:53 AM »
Very elegant Stew. Filing this one away for future reference!!
« Reply #4 on: February 13, 2018, 08:37:33 PM »
Not seeing the pivot lock either, could you post a detail sketch?  Like the idea though, thanks.
Offline sbwhart
« Reply #5 on: February 14, 2018, 06:55:02 AM »
Interesting device.
[/quote
Its just a pinch clamp the drawings attached so you can see how it works
Stew
Offline Andy
« Reply #6 on: February 14, 2018, 10:48:54 AM »
Thanks Stew,  I see what you did now  :slap:
« Reply #7 on: February 14, 2018, 04:37:24 PM »
Thanks Stew.
