Author Topic: Two Cylinder Engine  (Read 16040 times)
Re: Two Cylinder Engine
« Reply #165 on: March 17, 2019, 08:18:26 AM »
Thank you Dave  :ThumbsUp:
Next up were the various brass electrodes for the distributor. I did consider making the centre electrode from graphite but didn't have any suitable material. The output electrode were turned just using a parting tool. I made a spare as they look like something for the swarf Gnomes  ::) The rotor electrode was hand filed to shape and superglued in place. Finally I set the phasing between the cam and the rotor arm and drilled and tapped the fixing hole. The RT was used as it was already fitted and is a good way of holding round things.
« Reply #166 on: March 17, 2019, 09:26:18 AM »
Hello Roger,
Looking really good :ThumbsUp:
Have a great day,
Offline Zephyrin
  • near Paris, France
« Reply #167 on: March 17, 2019, 10:23:30 AM »
very interesting job on the distributor, thanks to share !
first class use of the small tooling you have, this mill looks quite accurate.
Offline Kim
« Reply #168 on: March 17, 2019, 03:32:03 PM »
Nice work on the distributor, Roger!  That's lots of shiny little bits you made  :)
« Reply #169 on: March 17, 2019, 05:45:04 PM »
Hi Roger, always watching every progress.
« Reply #170 on: March 18, 2019, 06:00:59 PM »
Thank you all for your support  :ThumbsUp: Zephyrin, I have found the small Proxxon drill and mill very useful. I have a very small workshop they will sit out of the way on a shelf when not in use. As my main machine is a combined Lathe and Mill I can do small milling jobs without having to convert from lathe to mill and back again. I am currently investigating the FD150/E micro lathe so I can make small bushes and adaptors whilst I am in mill mode.
Next up were the clamps for the distributor cap. These were made from 8mm aluminium bar drilled 3mm and then half milled away. I was quite impressed at the accuracy of the two parts  :) Two clearance flats were then milled on the same side. I then faced the water pump gears to size, giving about 0.1mm clearance to allow for thermal expansion (found the hard way on the horizontal engine  :( ) The key way was cut with the broach I made for the previous pump. Now I need to make a 2mm stainless steel key.
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #171 on: March 18, 2019, 06:55:49 PM »
Looking good Roger!  :ThumbsUp: :ThumbsUp: :ThumbsUp:
The engine is coming together nicely.  :popcorn: :popcorn: :popcorn:
« Reply #172 on: March 20, 2019, 05:14:51 PM »
Cheers from the popcorn gallery, it's looking good Roger! :popcorn:
« Reply #173 on: March 31, 2019, 10:10:32 AM »
Thank you for your interest  :ThumbsUp:
Finally a bit of workshop time on this. The water pump drive key was milled from a length of 3mm stainless steel and the ends were rounded by filling. When I assembled the gears they didn't turn smoothly and on close inspection the force of cutting the keyway had stretched between two teeth  :( I tried again this time with the gear held in a 14mm collet as I did for my horizontal engine, all ok  :)
I had decided I didn't really need to flange the water inlet as things were a little tight so I Loctited a stub of brass pipe in place. Finally I used my new toy to put cones in the end of some 4mm grub screws for the tappet adjusters starting with a centre drill and following with a 3mm drill.
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #174 on: April 03, 2019, 11:24:46 PM »
Coming together nicely Roger!
I like your new toy!  :popcorn:
