Author Topic: Not a Cretors (for a change)  (Read 1770 times)
Offline tinkerer
« on: February 03, 2018, 09:24:44 PM »
Here is a cute Kingery popcorn/peanut wagon a friend of mine owns. Thought maybe a different maker might interest others.  The engine is a near copy of the cretors. The corn popper is a dry popper. There was some disagreement as to the best way to pop corn. Cretors patented the popping of corn in a seasoned (flavored) oil (lard back then LOL). Others thought the corn should be popped dry (air popped?) then buttered.
You never know what you can do, till you try. Don't be afraid to try & fail. We learn more from our failures than our successes.
Offline tinkerer
Re: Not a Cretors (for a change)
« Reply #1 on: February 03, 2018, 09:27:27 PM »
Some details of the engine. It's a near copy of the Cretors but a few slight detail difference.
Offline tinkerer
« Reply #2 on: February 03, 2018, 09:28:44 PM »
last ones
« Reply #3 on: February 03, 2018, 09:32:00 PM »
Nice looking engine, thanks for the pictures.
With the amount of popcorn consumed while watching threads around here, seems like we should all make one!
« Reply #4 on: February 03, 2018, 11:06:26 PM »
It looks like the crank end of the cross head guide has a 'foot' on it that attaches to a pad on the crank bearing casting. The models I've seen make the cross head guide one piece with the crank end, and so much harder to make...???
Nice engine, and cart!
« Reply #5 on: February 04, 2018, 12:50:11 AM »
That cart looks to be in great shape indeed. Pete, the Myers half scale is the same, a foot on the crosshead guide that attaches to the bearing stand.
Offline tinkerer
« Reply #6 on: February 04, 2018, 06:08:15 AM »
Pete: Yes there is a shoe on the bottom (area of most wear?) if you notice the front of the crosshead slide is straight also. That's a slight difference detail as well.
Offline tinkerer
« Reply #7 on: February 04, 2018, 06:17:07 AM »
The flyball design is a bit different than Cretors too & the steam plumbing crosses over the cylinder. Instead of staying back behind. These are some of the slight differences I'm noticing between the original makers. Haven't had a chance to study a Dunbar up close yet.
Offline tinkerer
« Reply #8 on: February 04, 2018, 06:24:50 AM »
Found a Stutsman Ideal wagon stashed in the back corner of a barn. It's been changed over to electric.
