Author Topic: R8 Drawbar Questions  (Read 6696 times)
« on: January 21, 2018, 05:40:23 AM »
As you may have seen in my other post, today was the first day I used my new Grizzly mill the way it was supposed to be used.  But I have a few questions about the R8 drawbar.
First question
How do you tighten it securely?
When I use my 3/4" wrench to tighten the drawbar down, the spindle moves.   There are some flats on the end of the quill that I could use to hold it steady, but they are wider than any wrench I own – its like 1 1/2" across flats or something.  (more than 1 1/4" for sure).
Do you NEED to use something to hold the quill end steady while you tighten?  Or is just snugging it up as best you can with the quill wiggling around good enough?
I used a pair of channel locks today, since that's all I had that would reach between those flats.  But I don't want to mark up the quill, so I think I need to find something better.  Do you guys use anything here?
Second question
I have been able to use several different R8 collets and holders in the mill, but when I went to try and use my new R8 drill chuck, it didn’t work.  I tightened the drawbar as far as it would go, but the chuck still wiggles up and down about 1/8”.  That doesn’t seem right.
So, I took the drawbar out and did some investigation with the R8 holders that would tighten up, comparing it to the R8 drill chuck that won’t, and here’s what I see.
It looks like the R8 Drill Chuck doesn’t let the draw bar screw in far enough to draw up tight – it bottoms out for some reason.  In most of the R8 holders the drawbar hole goes all the way through, even though it is only threaded part of the way.  So you can tighten the draw bar as far as is required.  But the Chuck only lets the drawbar go so far, then it bottoms-out.
Here’s a look at one of the working R8 holders with the drawbar screwed in as far as it will go.  Note that there is about 14.5” between the edge of the holder and bearing surface of the drawbar at the top.
And here’s the drill chuck screwed into the drawbar as far as it will go till it bottoms out.  You can see that 14.5” doesn’t get you to the same place on the R8 holder.
This is a close up – you can see there’s still 1/4” to 3/8” of threads to go, but the drawbar has bottomed out.
So, it seems I need to shorten my drawbar, or I need to figure out how to make the drawbar hole in the drill chuck deeper.  The second one seems hard, and I don't want to screw up the nice new keyless chuck, so I’m focusing on the first one.  My first thought was to make a 1/8” wide spacer, or use a stack of washers, to move the bearing face of the drawbar down some.
But looking at the top end of the drawbar, it looks like there’s a roll-pin holding the top in place so it won’t turn.  I was wondering if I could push that out and screw the hext nut on the drawbar another 1/8”or so.  Then I could make a new hold for the roll pin.
Do those sound like reasonable options?  Are there better ones?  Any other suggestions?
Thanks for the help!
PS Are R8 collets that variable?  Why don't they all fit without me having to make changes like this?  Seems like they would be standard or something... :(
Re: R8 Drawbar Questions
« Reply #1 on: January 21, 2018, 07:32:47 AM »
The R8 SX2.7 I have on loan came with a pin spanner that fits the two holes in the end of the spindle
You could always place an 1/8" washer under the drawbar nut which will have the same effect as shortening the bar, I had to do that on one of my MT3 Drawbars.
« Last Edit: January 21, 2018, 07:36:33 AM by Jasonb »
« Reply #2 on: January 21, 2018, 08:24:54 AM »
Hi Kim, is it not possible to use a thick washer at the top under the hexagon, only If the R8 chuck collet  is in use ?
« Last Edit: January 21, 2018, 08:28:20 AM by fumopuc »
« Reply #3 on: January 21, 2018, 08:26:18 AM »
Hi Kim,
Drawbars - I have four for H and (currently) 2 for Tgs - threads and lengths are different. I also have a collection of spacers I have made to go under the top nut rather than have yet more different length draw bars  :)
As for tightening: an R8 collet needs a spanner on the bottom and top to pull it into the taper and tight with the tool. I am surprised the mill did not come with one. It is one of those mills that needs three hands when you are using collets - one for each spanner and the third for the tool  :facepalm: But you do gain head space  ::)
I would suggest you make yourself a couple of dedicated length draw bars and try to use a short spanner nut on the end.  :thinking: Maybe you could consider something which you can tighten the collet sufficiently by hand to hold the tool in place - both the BCA and Sexy have a knurled knobs :embarassed: which can be used to grip the tools before the finally tightening.
Offline Ramon Wilson
  • Suffolk in the UK
« Reply #4 on: January 21, 2018, 09:08:59 AM »
Hi Kim,
I had a similar problem on my new mill 'cept it doesn't even have flats on the quill!
A simple solution for me and may be for you is to remove that long nut and make two nuts from it. One, with the cross hole still in, shorter than the other. Replace the longer nut on the draw bar and down the thread. Screw the shorter piece on until it is level with the end of the draw bar then drill through the cross hole and replace the dowel locking pin.
You can now pull up any tooling using two spanners of the same size, one on the fixed nut the other on the longer nut below. I have this system on both mills and it works just fine - you do not need to graunch tooling up too tight in the taper anyway.
Hope that helps - if you need me too I'll take a pic of them for you
Regards - Tug
Offline Ian S C
« Reply #5 on: January 21, 2018, 09:43:20 AM »
My Rexon mill has a built in locking pin that engages a hole in the large pulley on the spindle. I have a number of draw bars, 10 mm, 3/8" ? UNC/BSW, and a 5/16" UNC for some homemade  #3 MT fittings. Where Kims machine has flats on the spindle nose, mine has a thread, onto which I screw my large diameter fly cutter, no draw bar needed.
Ian S C
« Reply #6 on: January 21, 2018, 12:15:40 PM »
My CNC mill uses a 36mm wrench to hold the spindle while I tighten the drawbar with a 12mm wrench.  I also have used washers or other spacers to shorten the drawbar when necessary.
Offline stevehuckss396
  • Sterling Heights, MI USA
« Reply #7 on: January 21, 2018, 02:20:40 PM »
My mill has a spindle brake handle. Looking at pictures of your mill on the interweb I saw a handle on the right side just under the motor. Is that a spindle brake?
Offline Doc
  • USA ND
« Reply #8 on: January 21, 2018, 02:38:20 PM »
 The draw bar if like the ones I've seen it the past do have a thick spacer. That is there so when or if your threads go bad at the collet end you cut it off and take the spacer out. They are made that way so you get a double use out of them.
Offline wagnmkr
  • Lindsay, Ontario, Canada
« Reply #9 on: January 21, 2018, 02:39:08 PM »
Just mill a wrench from flat bar stock. I made two of them that way and they work a treat.
Tom
« Reply #10 on: January 21, 2018, 03:12:05 PM »
Regarding the spindle lock...this may not apply to you but may help some one else.
My mill also requires 3 hands and when using a collet I've had the cutter drop out as I loosened the drawbar.
I found this on the internet.
1st photo shows the drawbar.
2nd photo shows a stop I 3D printed. When loosening the drawbar, it prevents the spindle from turning.
Even though it was printed in a bright color to catch my attention...it's still easy to forget it's there when turning on the machine.
I'm going to attach something (like a bright red warning tag on a string) to it that either hangs down into the work area or over the start button.
« Reply #11 on: January 21, 2018, 03:12:39 PM »
Thank you everyone for the excellent and detailed answers.  I really appreciate it.
Sounds like it's common, if not expected, for R8 collets to require different lengths drawbars. And that a spacer solution is very workable.  I will probably go that route, rather than have multiple drawbars.
And I will fix me up a nice flat wrench to use in tightening the collets.
Again, I certainly appreciate all the help! Thank you!
Offline Lew Hartswick
  • Albuquerque, New Mexico, USA
« Reply #12 on: January 21, 2018, 03:18:37 PM »
What?? You mean there isn't a spindle brake on that machine.  I can't imagine that (been using a Bridgeport for so many years). Sorry :-)
   ...lew...
Offline asm109
  • Jr. member
« Reply #13 on: January 21, 2018, 05:24:03 PM »
My mill has no brake and no wrench flats on the spindle.
However, putting the spindle in back gear adds enough friction that I can tighten the drawbar without any spindle rotation.  YMMV.
Offline Stilldrillin
« Reply #14 on: January 21, 2018, 08:09:36 PM »
When my R8 set arrived. Two of the collets had swarf, in the lower threads.
A 7/16 x 20 tap, soon cleared the way......
David.
