Author Topic: My Hoglet----IT RUNS!!  (Read 4816 times)
Offline Trevorc
« on: January 16, 2018, 07:13:42 PM »
Hello Everybody
I am chuffed ( pleased) :pinkelephant: to announce that I have completed my Hoglet and it ran first time. This has been a very interesting 15 months project which has been helped by advice received from this forum. I think it is appropriate to thank in particular Ron aka ozzie46 for his advice on timing the engine- just do as he says!!!
I think this can be described as a mid Atlantic version. Fasteners are nearest metric equivalent whilst Imperial sizes are used for oilite bushes and piston rings etc. These were obtained from USA via a friend- the cost of Imperial items in UK is rocketing. I tried to buy Imperial size materials but found that they weren't-not metric either. Some of the aluminium was sold as Imperial but it was undersized. The precision ground steel ( drill rod) wasn't to the nominal 3/8 inch diameter. It was about 1 thou undersize and this caused problems when building the flywheel. I could not get the sides to grip the crank halves.
I am running it on Coleman's fluid plus 5% WD40.
Would the use of two stroke oil give better lubrication than the WD40?
I am also surprised how it quickly gets hot, should I use some sort of a cooling fan?
The proof that it runs can be found here:
<a href="https://www.youtube.com/watch?v=Axo031Rn4YI" target="_blank">http://www.youtube.com/watch?v=Axo031Rn4YI</a>
I have previously built two other i/c engines. One was a small hit and miss engine Little Brother by Paul Breisch and the other was a modernised replica of Henry Fords experimental engine from 1893 as described in Gas Engine Magazine of March 2008 by Leon Ridenour. These have never run properly/at all. Perhaps I should go back to them.
I can thoroughly recommend this engine, it does what it says on the tin!!
Regards
Trevoc
Re: My Hoglet----IT RUNS!!
« Reply #1 on: January 16, 2018, 07:45:37 PM »
Excellent  :praise2:  :praise2:
Without any air flow it will heat up quickly. As most of WD40 is kerosene/paraffin which will probably act more as a fuel 2 stroke oil will give better lubrication, but if it runs ok probably no real problem.
« Reply #2 on: January 16, 2018, 07:59:39 PM »
Nice, makes me want to finish mine :-[
« Reply #3 on: January 16, 2018, 08:19:09 PM »
Congratulations Trevoc.  Good runner and very nicely done.
Offline Sleddog
  • South East South Dakota, USA
« Reply #4 on: January 16, 2018, 08:24:04 PM »
Congratulations! Thanks for showing us.
« Reply #5 on: January 16, 2018, 08:35:05 PM »
That sounds fantastic!! Congratulations on a fine looking (and running) engine!!
Offline Doc
  • USA ND
« Reply #6 on: January 16, 2018, 08:40:49 PM »
Nice job it does sound nice, GOOD JOB!
« Reply #7 on: January 17, 2018, 01:15:37 AM »
Trevork--Great job, very nice engine. Yes, it will definitely benefit from a cooling fan.---Brian
Offline Jim Nic
  • Buckingham, UK
« Reply #8 on: January 17, 2018, 10:07:44 AM »
Great sounding engine.  Well done.
Offline Ramon Wilson
  • Suffolk in the UK
« Reply #9 on: January 17, 2018, 11:32:08 AM »
Congratulations on a very nicely made and finished engine Trevor - runs and sounds very nice too  :ThumbsUp:
I have yet to make a 'sparkie'- it's results like yours that make me want to do so.
Regards - Ramon
Offline scc
  • Lancashire, UK
« Reply #10 on: January 17, 2018, 11:49:15 AM »
Very nice.   Well done.         Terry
Offline ShopShoe
  • Central Iowa, Central USA
« Reply #11 on: January 17, 2018, 12:58:12 PM »
Well Done, and Congratulations.
Gotta love the sound of these engines.
--ShopShoe
Offline ozzie46
« Reply #12 on: January 17, 2018, 02:02:48 PM »
I set up a 10 in, fan to blow on mine and it will run quite a while. Several minutes in fact.
Offline Chipmaster
« Reply #13 on: January 17, 2018, 02:43:19 PM »
Excellent, looks good and sounds great.
Andy
Online Vixen
« Reply #14 on: January 17, 2018, 02:55:26 PM »
It's a fantastic feeling when your baby runs. Well done
