Andrew...that was a very helpful and interesting link. Thanks!Are you the same Andrew as the author?
You may have to indicate the chuck true to the spindle. Indicate the OD of the chuck, or, better yet, a known round piece of stock tightened in the chuck.
The rh lever on your apron is for carriage feed, the small one is for cross slide (facing) feed. So use the RH one for what you are doing at present.Gerrit
I setup a .0005 test indicator and a piece of 1/2" bar from a printer.Lowered test indicator and zeroed it.Turned chuck (by hand) and needle swung just over 5 marks in both directions (0.0025mm)
Quote from: zeeprogrammer on January 15, 2018, 07:06:09 PMI setup a .0005 test indicator and a piece of 1/2" bar from a printer.Lowered test indicator and zeroed it.Turned chuck (by hand) and needle swung just over 5 marks in both directions (0.0025mm)Zee, check what dial indicator you are using. A 0.0005 indicator is generally an imperial one where one division equals 0.0005" or 5tenths of an inch not 0.0005mm Provided all jaws are in/out the same amount you should not get vibration from a 4-jaw
I guess more important is for Zee to spend some quality time with the manual :-)
