Author Topic: 1/3 Scale IHC Famous  (Read 21361 times)
Offline TobyTetzy
« on: December 07, 2017, 03:54:16 AM »
Hello and good morning.
Here are the the first pictures of our IHC Famous in 1/3 scale.
It's build of the OnderStoom Plans from the Nederlands.
My Father beguns to build the steel parts and I begun to build the cart from ash-tree.
Regards Toby
Re: 1/3 Scale IHC Famous
« Reply #1 on: December 07, 2017, 12:06:10 PM »
Hi Toby, so you are building three of these at the same time?  Beautiful work so far and I love the joinery work on those Ash bases too!!
« Reply #2 on: December 07, 2017, 12:18:35 PM »
Welcome Toby!   Nice Work!
« Reply #3 on: December 07, 2017, 01:10:20 PM »
They look good Toby, brings back memories of when I built a 1/5th scale one
Offline TobyTetzy
« Reply #4 on: December 07, 2017, 06:12:03 PM »
Hello,
Bill, yes, we build tree of it.
One for my Father, one for me and the last one, if the others don't run well.  ;)
Today my Father had finished the crankshafts and I made some woodworkings again.
Question, how should I treat the wood so that it becomes oil and gas resistant?
Should I also dye it a little darker?
The last pictures shows the original drawing of the Cart and my drawing in Inventor.
Regards Toby
And here is the pipe I want to use for the Cart Wheels.
It's 114x10 mm.
« Last Edit: December 07, 2017, 06:15:56 PM by TobyTetzy »
« Reply #5 on: December 07, 2017, 06:36:23 PM »
I tend to use an oil finish such as "danish oil" or more recently one of the oils which also contain wax such as Osmo Poly-x. This would be a similar German product, they also do the Danish oil. Both easy to apply but make sure you wipe off any excess oil after about 15mins as any left sitting on the surface will not dry and you will have a sticky surface.
https://www.dictum.com/en/surfaces/surface-protection-colours/oils/810060/asuso-nl-hard-oil-wax-water-repellent-silk-matt-750-ml?ftr=_7__97_1_12_12
Offline TobyTetzy
« Reply #6 on: December 08, 2017, 09:02:43 AM »
thank you Jason for reply.
What do you think about this
http://www.clou.de/index.php?id=189&item=13
http://www.clou.de/index.php?id=189&item=9
Or any other of this? Painting is magical for me  :(
http://www.clou.de/clou-diy/produkte-diy/?u=4
Today I make the fist "rear axle support", is it the name of it  ::) .
I used my CNC Mill and mill it of 3mm brass.
Regards Toby
« Reply #7 on: December 08, 2017, 02:52:03 PM »
Very nice work on the axle support Toby. The brass will look very nice too. As for wood finish, I usually use a solvent based wood stain such as Minwax over here in the USA. This is a water thin stain you can either brush on or apply with a cloth and is available in many shades depending on the base wood you are staining. That is followed by 2-3 coats of a polyurethane gloss finish from a spray can. This has held up well for me against oil and fuel.
Offline TobyTetzy
« Reply #8 on: December 16, 2017, 09:47:53 PM »
Hello,
only a little update, because I wait for some more materials ;-)
3mm brass for the other Axle supports, 5x5 and 6x6 stainless steel for screws.
At this time I begun to make the first Box and make some colour tests.
1st is "Osmo 3072 Bernstein Hardwax Oil"
2nd is "Osmo 3073 Terra Hardwax Oil"
3rd  is only "Clou Holz Siegel" on Ash
4tht is "Clou Oak medium stain" and "Clou Holz Siegel"
Regards Toby
Offline TobyTetzy
« Reply #9 on: December 18, 2017, 07:38:02 AM »
Hello,
yesterday I paint the Ash with Osmo Hardwax Oil "Bernstein".  :)
I like the result.
I also thinking about the switch for the ignition.
Do you think it's ok so? Or is it too big?
Regards Toby
« Reply #10 on: December 18, 2017, 07:50:06 AM »
Handle looks too small on the switch and maybe a bit of a fancy design, have you based it on a real one?
This is the Gade one I copied
Offline TobyTetzy
« Reply #11 on: December 18, 2017, 08:02:33 AM »
Hello,
I found pictures shows this switch.
Last picture shows your switch.
Regards Toby
« Reply #12 on: December 18, 2017, 08:18:44 AM »
Toby, I did not enlarge all your thumbnails, in the last one it looks like you had a small turned wooden handle on the switch, I can see now it is just the way the light hits the twisted brass :-[
PS wood colour looks about right.
« Reply #13 on: December 18, 2017, 06:45:02 PM »
Beautiful wood work Toby!
I like the switch too, a bit different than what you usually see.
I'm enjoying your project.
Offline TobyTetzy
« Reply #14 on: December 19, 2017, 07:06:34 AM »
Hello,
thank you for reply.
Does anyone know the colour of the IHC's?
I want to use RAL colours red and black.
Red engine
black tank and flywheels.
Here is our PowderCoating dealer.
He had RAL 3000, RAL 3001, RAL3003
http://pulvertech.de/de/pulverlack-beschichtungspulver/ral-farben-glanz
Regards Toby
