Author Topic: 1/3 Scale IHC Famous  (Read 13533 times)
Offline TobyTetzy
Re: 1/3 Scale IHC Famous
« Reply #90 on: October 17, 2019, 10:29:35 AM »
Hi,
thank you for the answers.
Here's an attempt that ignites the engine only one cycle.
For this purpose, the air intake was slightly reduced.
I just stuck some tape over it.
Unfortunately, the engine does not work after a short time.
Jason, is this possibly a sign that the engine gets too much air, and thus the mixture is not right?
You had written to reduce the Venturi a bit.
This would make the air flow higher in less air, right?
Toby
<a href="http://www.youtube.com/watch?v=lx7vleOgTOw" target="_blank">http://www.youtube.com/watch?v=lx7vleOgTOw</a>
Offline TobyTetzy
« Reply #91 on: October 21, 2019, 11:10:58 AM »
Hi,
I built the generator for testing at the IHC today.
With the electronics you can adjust the load variably.
I did not think that the generator needed so much power.
You can even stop the IHC with it.
Greeting Toby
<a href="http://www.youtube.com/watch?v=djQ4LADizIA" target="_blank">http://www.youtube.com/watch?v=djQ4LADizIA</a>
