So I figure 270+360=990. That will rotate A one turn. To get one move rev the next A code of A0 results in 3 full revolutions.
Is't there a way in the parameters to "tune" the rotary axis to reflect the correct movement in degrees?
G thanks fellows, the G91 worked, and i for got to try G92. TomorrowQuote from: Noitoen on November 30, 2017, 08:22:15 PMIs't there a way in the parameters to "tune" the rotary axis to reflect the correct movement in degrees? In my software you just tell A how many steps per degree. There may be more, i am no expert at this.
