Author Topic: Gasket for Hoglet cylinder heads  (Read 1746 times)
Offline Trevorc
« on: November 23, 2017, 01:25:33 PM »
Hello Everybody.
The drawings for the Hoglet makes no mention of any gasket for the cylinder heads. Can those that have built this engine please tell me what they used as a gaskets. I presume that a gasket is needed, cant imagine that a gasket less joint will be gas tight at pressure.
If gaskets are used what material are they made from.
Thank you
Trevorc
Offline ozzie46
Re: Gasket for Hoglet cylinder heads
« Reply #1 on: November 23, 2017, 01:43:34 PM »
There is no need for a gasket as it has a narrow "squish band " of metal approx .125 wide around the rim of the cyl.
I have made 5 Hoglets and not one has needed a gasket. It's the same principle as a model airplane engine.
« Reply #2 on: November 23, 2017, 08:34:03 PM »
I have never had luck sealing cylinder heads to cylinders using "squish bands". Use a piece of 0.030" general purpose gasket material from your local automotive supplier. It's cheap and it works, and the heat doesn't seem to bother it.---Brian
Offline Ian S C
« Reply #3 on: November 24, 2017, 02:20:19 AM »
You could use a thin anealed copper gasket if you are worried that it will get too hot for a paper type one.
ian S C
Offline gldavison
  • Tarkio, Mo.
« Reply #4 on: November 24, 2017, 11:11:15 PM »
I use .015" teflon sheet for my Hoglet. Been on there over 4 years. No problems yet.
Gary
Windows 10 & 11, Alibre Design Pro V27, IntelliCADPro6, CamBam, Mach4, 3D Printers, Cetus, Anet ET5 X
15" South Bend, 10" Logan lathe, Grizzly square column mill, CNC router & Hot wire cutter. Lagun FTV-1 knee mill, Sherline mill & lathe
Offline Trevorc
« Reply #5 on: November 25, 2017, 06:32:18 PM »
Thank you every one. I have enough to gone on now.
Trevorc
