Author Topic: Austin seven  (Read 12480 times)
Offline Tonyr
Austin seven
« on: November 19, 2017, 04:42:50 PM »
Hello,
I haven't been active on this forum for quite a while.
I haven't been idle though.
A couple of years ago I purchased a 1932 Austin Seven car, which takes up a lot of my time.
I decided to try and make a model of the Austin engine.
Here are a few photo's of the progress so far.
I have more photo's of the individual parts if anybody is interested.
Tony
Re: Austin seven
« Reply #1 on: November 19, 2017, 06:16:26 PM »
Nice looking model excellent details! How large is it? Would definitely be interested in more pictures.
Re: Austin seven
« Reply #2 on: November 19, 2017, 07:31:13 PM »
Interesting model  :ThumbsUp:  :ThumbsUp: I remember reading about Austin 7 engines used in competition were the two middle pistons were machined slightly shorter to allow for the whip in the two bearing crankshaft  ::)
Offline Tonyr
Re: Austin seven
« Reply #3 on: November 19, 2017, 08:31:08 PM »
Crueby.
The engine is about 1/3 scale, the block is aprox 4 inches long.
I have the photo's on the iPad and they are too large to post.
I will post the pictures when I figure out how to shrink them, any help would be appreciated.
Tony
Re: Austin seven
« Reply #4 on: November 19, 2017, 08:37:16 PM »
Tony, here is a free one that will let you resize batches of pictures at one time. It seems to be ok, you will see under the advanced options where you can select the output size. For forum use 800 x 600 is more than adequate.
www.faststone.org/
Offline Tonyr
Re: Austin seven
« Reply #5 on: November 19, 2017, 08:49:22 PM »
Bill,
Thanks for the link but I don't think it works on the iPad.
Maybe I will have to do it on the laptop.
Tony
Re: Austin seven
« Reply #6 on: November 19, 2017, 08:52:35 PM »
Yes sorry about that. Surely there are similar free programs for the iPad though. Maybe an iPad used will chime in here with a suggestion.
Offline Tonyr
Re: Austin seven
« Reply #7 on: November 19, 2017, 09:13:54 PM »
A couple of photo's of the crankshaft to test photo resize.
Ton
Offline Tonyr
Re: Austin seven
« Reply #8 on: November 19, 2017, 09:14:52 PM »
Try again !!
Offline Tonyr
Re: Austin seven
« Reply #9 on: November 19, 2017, 09:22:02 PM »
More photo's.
Cylinder block and cam manufacture.
Tony
Re: Austin seven
« Reply #10 on: November 19, 2017, 09:42:13 PM »
Very well done!
Re: Austin seven
« Reply #11 on: November 20, 2017, 04:31:17 AM »
Hi Tony, impressive.
Offline ThomasM
    • My modelengines
Re: Austin seven
« Reply #12 on: November 20, 2017, 02:21:17 PM »
Hello Tony,
Your austin engine looks very nice. I currently build a very similar engine.
I will follow until it fires up.
Best regards,
Offline Tonyr
Re: Austin seven
« Reply #13 on: November 20, 2017, 05:32:05 PM »
Thanks Achim.
Thomas, I have been watching your engine.
It does look very similar to the engine I am building.
I have been watching to see if I can get any good idea's from your build.
Tony
Offline Tonyr
Re: Austin seven
« Reply #14 on: June 22, 2019, 03:40:10 PM »
Hello,
I haven’t posted on this build for a while.
Other than the short detour whilst I got the Bruce atmospheric engine running, I have been working on the Austin engine periodically.
I have the cylinder liners fitted and the Pistons and Conrods finished.
The Dummy dynamo is almost complete.
The Dynamo has an aluminium disc with magnets inset.
This will fire the ignition system via a Hall effect sensor.
Tony
