Author Topic: Austin seven  (Read 12572 times)
Offline Tonyr
Re: Austin seven
« Reply #45 on: August 11, 2020, 08:01:11 AM »
Hello Art,
Yes on the real engine that is the dynamo.
It is driven from the camshaft and the distributor is driven from a gear on the end of the Dynamo.
On my engine I have adapted it the fire the ignition.
There is an Aluminium disk in there with magnets fitted to trigger a Hall effect sensor.
One of the main challenges is making the engine look like the original whilst having the functionality at the small scale.
Obviously the original has points in the distributor.
It is quite difficult to fit things in, so there are a few compromises.
The carburettor was another challenge.
Superficially it will look the same as the Austin Seven engine hopefully even to the trained eye.
Thanks
Tony
Offline Tonyr
Re: Austin seven
« Reply #46 on: October 01, 2020, 05:46:31 PM »
Hello,
I bit more progress.
It doesn’t look much different but I suppose when all the big bits are done the smaller parts don’t change the appearance much.
I have made the valve cover and the fan pulleys.
I have also made the starting handle and associated parts.
I have added a photo of the offset being machined on the belt adjuster.
Thanks for looking
Tony
Offline Fowellbox
Re: Austin seven
« Reply #47 on: October 01, 2020, 06:47:01 PM »
That's looking really good and I speak as the former owner of a number of A7's.
Brian
Offline Tonyr
Re: Austin seven
« Reply #48 on: August 11, 2023, 08:09:25 PM »
Hello,
I haven’t been on this site for quite a while. It’s not that I had any problems with it.
I retired from work about 18 months ago and have been really busy with new things.
I hadn’t been in the workshop for ages. This week I decided it was time I got back in there.
My Austin seven engine has been more or less finished since I retired. I decided this week to see if I could get it running. After a small amount of setting up the engine runs.
The link below should take you to a video of it running.
There is a bit of work now to tidy it up and finish it as a display.
Thanks
Tony
https://youtube.com/shorts/3ul7Z3comAI?feature=share
Offline A7er
  • Cornwall, UK
Re: Austin seven
« Reply #49 on: August 11, 2023, 08:49:04 PM »
That is a fine looking and sounding engine Tony. Do you think you will make a scale radiator and surround to go with it?
Re: Austin seven
« Reply #50 on: August 11, 2023, 08:53:44 PM »
You could put it up here - like this :
#Invalid YouTube Link#
Lovely Engine and it runs like a dream too  :praise2:   :praise2:
I also thought about a radiator during the video ....
Per        :cheers:
I could have sworn that the Link worked when I posted it     :killcomputer:    :wallbang:
« Last Edit: August 12, 2023, 09:17:02 AM by Admiral_dk »
Offline Tonyr
Re: Austin seven
« Reply #51 on: August 11, 2023, 08:55:38 PM »
Yes, that is the plan. I will sit it on a model of the chassis with a radiator at the front.
I am back in the mood for it again after having some time away from it.
Offline A7er
  • Cornwall, UK
Re: Austin seven
« Reply #52 on: August 12, 2023, 03:40:52 PM »
I was hoping you would include a chassis!
