Author Topic: Home made counterbore, working on Stuart D10  (Read 2233 times)
Offline geoff5269
« on: November 16, 2017, 12:21:28 PM »
I decided to tackle a D10 as respite from the more challenging builds I have done recently but I find every build is a new challenge.
All is going quite well but I found I needed to counter bore in a hard to reach flange of the upstand as the curved surface wouldn't let the nuts seat properly.
the tool would have to be at least 80mm long and narrow and I couldn't find anything to buy so I had to try and make one. So I used 5mm silver steel drilled for pilot and then filed 4 teeth onto it and then inserted a pilot. I didn't try to harden it I thought as long as it works for this job that's fine. And it worked and the nuts seat down as they should so it's always worth trying.
I am enjoying working on this engine except for having to convert all the measurements to metric which can lead to errors.
Geoff
Re: Home made counterbore, working on Stuart D10
« Reply #1 on: November 16, 2017, 12:30:23 PM »
Looks like that worked well  :ThumbsUp: Any chance of a pic of the cutting end of the tool?
Geoff
Its annoying that so many of the model engine designs are showing their age and still use Imperilous measurements  :disappointed: I have a look up chart (attached) that I keep to hand and mark up my drawings in red with modern measurements  ;)
Offline gerritv
  • St Catharines, ON
« Reply #2 on: November 16, 2017, 01:39:52 PM »
That is a very handy spreadsheet, thank you Jo!
Gerrit
Offline geoff5269
« Reply #3 on: November 17, 2017, 11:56:14 AM »
Here's a pic of the cutting tool after it's use, lasted long enough to do the job.
Thanks for the conversion chart and BA sizes
Geoff
Offline Chipswitheverything
« Reply #4 on: November 17, 2017, 01:14:36 PM »
Hi Geoff, nice to see picture of your Double Ten coming along well.  I'm mucking about with two different No 10V's at the moment, had the bits of one since I was a teenager!, not a recent event! , and have done bits of work on it over the years, the other was a boot sale find with a fair amount missing, like flywheel, box bed....    Though, like you, I have done other and more complex model and toolmaking projects, I'd agree that the humble Stuart 10 has enough to it to give interest and a bit of a challenge.  As a model aimed at the beginner to the hobby, it would, I think,  test the inexperienced model engineer to make a decent "10".  Dave
