I would be interested to hear if any forum members have made their own broaches for cutting internal keyways, such as in the bore of a flywheel. I am looking, in particular at cutting a keyway with a taper of 1:100 to match the standard flywheel key taper.
I have read articles about making broaches from mild steel, then case hardening, but does anyone have experience of doing this or any tips on the shape of the cutting teeth?
I only have a couple of keyways to cut, one 3/32" wide, and the other 1/8" wide, so I am reluctant to pay out something like £60 for a couple of commercial broaches. I intend to cut the keyways on the lathe, effectively using it as a shaper. I have done this in the past using a parting-off type tool to cut a parallel keyway, but have never tried a tapered one.
