Author Topic: What kind of fuel for a (future) tiny 4 stroke engine ?  (Read 1642 times)
Offline Hagar
« on: November 05, 2017, 03:15:12 PM »
Hi everybody,
I'm studying my first IC engine. I chose a one cylinder 4 stroke engine.
Bore will be 14mm. Stroke will be 12mm. A very small thing but that's what my workshop is for.
Ring should be a Viton seal. I've read this solution works.
Piston is aluminum and sleeve is iron cast.
My question is : what kind of fuel should i use to make it run ?
Must i add any oil to ensure a good sliding wet ring ?
Thank you
Re: What kind of fuel for a (future) tiny 4 stroke engine ?
« Reply #1 on: November 05, 2017, 03:18:27 PM »
Hagar, over here in the States, many folks use Coleman fuel with something like 2% oil (I prefer Marvel Mystery Oil). I am sure some of our UK and European members can point you to the equivalents in your area.
Offline RayW
« Reply #2 on: November 05, 2017, 04:34:05 PM »
I have just purchased a litre of Coleman equivalent fuel made for Primus, the camping stove people.You should be able to find it at most camping or outdoor equipment shops. Expect to pay about £8 per litre. The advantage over petrol is that there is a lot less smell.
Alternatively, you could use either butane or propane with a suitable regulator.
Ray
Offline Hagar
« Reply #3 on: November 05, 2017, 08:02:33 PM »
Coleman fuel seems to be a good refined gasoline. This trade is not available, here in France. :'(
I think a high quality fuel for house stove should be very close to Coleman fuel. It's easy to find...
So, 2% is the rate for oil added. A 2 stroke engine oil of course.
Thank you for your answers.
