Author Topic: How do you paint your engines ?  (Read 5700 times)
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
« on: October 31, 2017, 07:54:42 PM »
Hi,
I'm just wondering how others go about painting their models to get a good even finish ?
I have a small airbrush set up that seems to work great some days but not so good on other days so the last engine I painted I had a go at brush painting with Humbrol enamel, that seemed ok but there are a few spots that the finish isn't great so I thought about trying car body work spray cans this time.
Any thoughts on using spray cans ? is it easy to get a good even coverage without runs ?
What about buying better quality paint than Humbrol and brushing again ?
The engine I'm building is intended to run on steam so I'd like something that with withstand a bit of heat  :)
Thanks.
Re: How do you paint your engines ?
« Reply #1 on: October 31, 2017, 08:22:43 PM »
Hi Gas_mantle,
I am no expert but I have found that the primer is a key. I use Krylon "Cover Maxx", Ultimate Coverage primer and have not found any better.
Two coats of the primer with a fine sand paper between each coat ( like 1000 grit ).
The finish coat I use Krylon "ColorMaster" with 2 to as many as 4 coats. Again, fine paper sanding between coats.
Hope this will help.
Have a great day,
« Reply #2 on: October 31, 2017, 08:36:38 PM »
I do airbrush some of mine if I want a particular colour or finish, usually use Precision Paints enamels and their primers.
But mostly I use spray cans as they are convinient. bare steel or iron will get Halfords grey primer, aluminium, brass, bronze, etc I use an etch primer for usually U-Pol Acid8, for sand cast iron and some fabrications I use a filler primer such as U-Pol's High5 followed by the grey. Halfords colour more often than not topped off with a clear coat as they gives a deeper glossy look, fuel proof one for the IC engines.
Several light coats applied without getting too close will avoid runs.
this post shows my prep work
http://www.modelenginemaker.com/index.php/topic,4863.msg97803.html#msg97803
« Last Edit: October 31, 2017, 08:40:31 PM by Jasonb »
simplyloco
« Reply #3 on: October 31, 2017, 08:56:12 PM »
Taking my cue from Chris Vine's excellent book 'How NOT to paint a Locomotive', I made a miniature spray booth out of a plastic closable crate, complete with extractor vent and rear filter panel. I fitted a winding mechanism, essential when using thin spray paints, as it is then possible to turn the work as it is drying thus preventing runs. I also stole my other half's spare cake decorating turntable...
It works and it cost very little!
DSC01041 by inkaboat, on Flickr
Offline Mcgyver
  • Toronto
« Reply #4 on: October 31, 2017, 10:26:18 PM »
great thread topic. Its an area I wish knew more about so am hoping for lots good advice
« Reply #5 on: November 01, 2017, 01:43:36 AM »
As with hand filling i use brush painting ....i suspend all the parts onto threaded rod or bike spokes .  I use sable hair brushes and use primers first. When you paint it is better to do the detailed mouldings first and then the large flat parts last. when you use the brush you always brush off the edges never onto a corner. it is best after charging the brush to start a little bit further on from the last painted part and work back slightly. When i paint the parts ,to stop any dust being disturbed i do it when i get up ,or after spending time away in cafes etc .Also as you dont want any clothing fibres to adhere to the surfaces one can do it naked !!! with thin rubber gloves and a hair cap....hope this is not too much info....I also have a lightweight card box that a put over the newly painted parts.....
Offline Rustkolector
« Reply #6 on: November 01, 2017, 03:13:30 AM »
This question comes up from time to time, and my vote is still for a finish called Gun Kote. I build IC engines that accumulate a lot of oil at times, and I like to run them a lot. I wanted a no worry paint finish that could tolerate a harsh solvent like brake cleaner as well as heat. I tried many paints and finally decided on Gun Kote, and I have been very happy with it. It is a single part heat curing finish (bake 1 hr @ 325F or 2 hr @ 250F - toaster oven) that fixes the paint to the surface so well that it can only be removed by grit blasting. Preparation is #125 AL oxide grit blast which I normally do anyway to hide fine machining marks. No primer is used. I use an inexpensive air brush to apply Gun Kote at very low pressure. It goes on in thin coats so runs are easily avoided. It can also be applied wet or dry spraying to simulate smooth and cast surfaces. Gun Kote is available in a wide spectrum of colors with most colors available in gloss, satin, and flat. The advantages of Gun Kote are that it doesn't chip or peal, it adheres to all metals equally well even tough ones like brass and aluminum, it goes on very thin and doesn't hide detail or cause assembly interference problems, it is very heat tolerant, and I haven't found a solvent that effects it in any way. I suppose some would say that powder coating has many of the same attributes, but it cures at 400F which is only about 20F degrees below the melting point of 4% silver solder which many of us use on detail parts. That's too close for my comfort.
Jeff
« Reply #7 on: November 01, 2017, 07:42:42 AM »
I have a feeling there is something in Gun Kote which means it is not sold in the UK, Brownell's UK site does not list it.
Offline Gas_mantle
  • North Yorks - UK.
« Reply #8 on: November 01, 2017, 12:48:27 PM »
Thanks for the replies, it sounds very much like I need to start using a primer which up till now I haven't bothered with.
I'm not convinced my little airbrush set up is consistent enough for what I want, it's also difficult to get the right mix of thinners so that subsequent coats are all of the same shade.
I like the idea of making a spraying box from a plastic crate  :)
« Reply #9 on: November 01, 2017, 01:01:57 PM »
A lot of airbrushes put on too thin a coat for our robust requirements and need the paint thinned a lot which does not help with runs. Unless you have a heavy duty nozzle on the airbrush it will not cope that well with the coarse pigments found in enamel paints. Some of the small guns are better in this respect.
Thinning will not alter the shade of the paint, what you are likely seeing is the base metal colour affecting the finish shade as the paint film is too thin. This is another good reason to use the right primer as it will give a uniform base otherwise you risk a part made from say cast iron looking darker than one made of aluminium even though they have been painted with the same colour coat
Offline RayW
« Reply #10 on: November 01, 2017, 02:45:34 PM »
I have used both spray cans and brush applied paints in the past. Like Jason, I have used Halfords auto spray paints, but a word of caution, as mentioned on my Otto thread, shades of the same colour can vary from can to can.
For brushing paint, I generally use coach enamels from specialist paint suppliers such as auto paint factors, or companies who produce paints specifically for the vintage market.
My local auto paint supplier will mix whatever colour you require and will also put some of the paint into a spray can, at extra cost. This means that you are assured of identical colour matching on both sprayed and brush painted components. If you have purchased paint from, say, one of the specialist vintage paint suppliers, they will also put some of that into a spray can for you.
Ray
« Reply #11 on: November 01, 2017, 03:03:23 PM »
Also you can use a 'Tack cloth' to remove dust before painting..........
« Reply #12 on: November 01, 2017, 03:22:49 PM »
Wow, you guys really know your paint.  I'll be the heretic here, as I'm not a painter, just a bodger: :mischief:
The last painted bit I did (iron base casting for PMR #3) I took the time to chamfer all the sharp corners and mask the machined areas.  Then set it on a cardboard box just outside the garage door, and started spraying light coats of "Hammerite" paint (the kind advertised not to require primer).  First coat went on looking like a tint, but I let it dry for an hour per the can instructions, and then put the next coat on.  And so on, for about 4 or 5 coats.  Then waited a day, flopped it on its side and hit the bottom with a couple of coats.  Came out looking pretty good.
Aluminum, brass - why paint?  Both are pretty corrosion resistant in the raw.
(Ducking and running) ;D
Offline Stuart
  • Tilchestune UK
« Reply #13 on: November 01, 2017, 03:29:11 PM »
My problem with paint is I put it on inside out and it looks like a rough casting
The shiny finish is always on the inside and the side that should be on the casting is outside
It never looks any good  :wallbang: and makes me  :cussing: and  :paranoia: then I  :Director: and feel like  :toilet_claw:
But hey I woke up this morning and hope to do tomorrow  :Jester:
Stuart  :old:
« Reply #14 on: November 01, 2017, 06:28:32 PM »
Don't discount even the water based acrylic paints for airbrush use. I have found they hold up well and there are primer colors too for the base layer. Most are ready for use in airbrushes and clean up with warm water and soap is a snap.
