Author Topic: By Jupiter  (Read 77583 times)
Online Roger B
Re: By Jupiter
« Reply #465 on: October 09, 2019, 10:17:30 AM »
It is always good when you find an obvious problem. If you hadn't seen anything when you opened the defective plugs it would have been a bit of a head scratch  :headscratch:
Offline Graham Meek
Re: By Jupiter
« Reply #466 on: July 11, 2020, 11:29:30 AM »
I came across this post while searching for something else, the methodology mirrors that which I did in making the original 1/4" plugs. Since then I have made a 4.5 mm version using the same design. these were tested using an adaptor in the Project 2 cylinder engine.
Thanks for an enjoyable read and I am glad my design was of help to you.
My best regards
Gray,
Re: By Jupiter
« Reply #467 on: July 11, 2020, 12:35:44 PM »
Hello Graham,
I am pleased you happened upon this build story. I liked your design and the clever use of the fish spine ceramic for the hot end.  It's good to be able to tear down a duff plug and replace any failed parts. I now have all thirty plugs tested and working.
I believe I credited this plug design to you back in Reply #435 and on several further occasions. Great design, so credit where credit is due.
Stay safe
« Last Edit: July 11, 2020, 09:18:47 PM by Vixen »
Offline nj111
Re: By Jupiter
« Reply #468 on: July 11, 2020, 06:17:12 PM »
Good to see you here again Graham.  I shall also use your ideas! Nick
Nick
