Author Topic: By Jupiter  (Read 44234 times)
Online steamer
Re: By Jupiter
« Reply #270 on: December 16, 2018, 04:57:22 PM »
I for one, am thankful to see this build.   Mike, your work is an inspiration to me.   Watching this build has given me the inspiration to work through my recovery and get on with some of my projects.   Keep it coming!
Online Vixen
Re: By Jupiter
« Reply #271 on: December 16, 2018, 05:23:05 PM »
Thanks Dave, I hope the recovery is going well. You have been out for quite some time.
Online steamer
Re: By Jupiter
« Reply #272 on: December 16, 2018, 05:28:30 PM »
Oh I know   its frustrating!...  but its coming along.   And i know i have an even bigger project after!
Online Vixen
Re: By Jupiter
« Reply #273 on: March 21, 2019, 03:33:56 PM »
After a long winter's hibernation, it's back to work on the Jupiter.
The Bristol Jupiter engines were used to power many different aircraft types in the late 1920's, ranging from military fighters and bombers, to commercial transport and large passenger airliners. Bristol's offered several methods for starting the Jupiter engines to cater for the many different aircraft installations. Remember, these were the days before electric starters were available.
When the engines were mounted in the nose or lower wing, access was easy, so a motor vehicle fitted with a 'Huck's Starter' could be employed. A high level shaft from the 'Huck's Starter' vehicle was attached to a jaw coupling on the propeller hub to turn over the engine. This was a quick and easy way to start the engines at their home base but different arrangements were needed when the aircraft landed at an airfield without a 'Huck's starter' available for use.
The big Handley Page HP42 airliners, operated by Imperial Airways, presented a unique engine starting problem due to the height of the upper engines above the ground. A special air starter system was designed specifically for these difficult installations. Compressed air from a special 'air starter rig' was used to turn over the engines during start up. The 'air starter rig' contained a petrol engine driven compressor, a large air reservoir and a crude carburettor to add fuel to the starter air supply. The engines were fitted with an air distributor not unlike an ignition distributor. 'Air starter rigs' would be located at each stop on the scheduled route.
Almost all the Jupiter engines were fitted with 'hand turning gear' as standard. The 'hand turning gear' was located on the rear of the engine, it allowed the engine to be turned over and started by a pair of starting handles cranked by hand on either side of the engine. A lever in the cockpit engaged a dog clutch during startup. The dog clutch was automatically disengaged when the engine fired. There as a two stage bevel reduction gearbox between the hand cranking wheels and the engine's shaft. Here are some cross section drawing to show the workings. Note the huge spring which energised the over-centre linkage to engage and disengage the dog clutch
For the model Jupiter I decided to use something based on the 'hand turning gear'. I plan to use a cordless drill/driver for engine starting with a simple Jaw coupling between the drill and the engines input layshaft. The cordless drill's gearbox would provide the required speed reduction, so eliminating the need to replicate the double bevel reduction gears of the full size 'hand turning gear'. A dummy, non functional, reproduction of the original 'hand turning gear' would be added for appearance sake.
I started by machining the jaw coupling. The workpiece was mounted in my 4th axis stage on my Emco mill. The coupling was machined by coordinated movements in the X,Y and Z planes while the work was rotated, when required, by the 4th axis (the A axis)
I made two jaw couplings (one as a spare) and a bidirectional coupling intended to allow the crankshaft to be rotated in either direction, during the later stages of the build.
Here is the rear cover of the engine, showing the jaw coupling mounted on the input lay shaft, together with the 16 tooth input pinion. The rear cover contains the 'hand turning gear' , the pressure and scavenge oil pumps and the drive to the twin magnetos.
More to follow shortly
« Last Edit: March 21, 2019, 03:46:36 PM by Vixen »
Online Vixen
Re: By Jupiter
« Reply #274 on: March 26, 2019, 05:52:46 PM »
I don't know how many of you are still following this build. Sorry about the slow rate of progress.
Here are the two halves of the Hand Turning Gear Housing being machined. The six bolt holes were a very convenient way to hold the parts onto a backing plate. The inside and outside faces of both components were machined without disturbing this setup.
Part way through the machining. The two parts have been machined from five sides.The rearmost flange (side six) is still a rough square.
The rear flange is faced of to length and profiled to shape. The mounting holes are coordinate drilled and tapped 8 BA, without disturbing the position of the part.
The machine work on the Hand Cranking Gear casings is complete and will be followed by some careful hand finishing of the less accessible parts and to make them resemble a casting.
More to follow
Offline Johnmcc69
  • Erie Pa., USA
Re: By Jupiter
« Reply #275 on: March 26, 2019, 06:44:14 PM »
Still here, & still watching Mike!
 Great looking parts!
Re: By Jupiter
« Reply #276 on: March 26, 2019, 06:55:51 PM »
Another one quietly following your progress.
Re: By Jupiter
« Reply #277 on: March 26, 2019, 06:57:30 PM »
Great work Mike, enjoy seeing your progress!  :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn:
Re: By Jupiter
« Reply #278 on: March 26, 2019, 07:36:17 PM »
I think it is safe to bet on this thread having a lot of readers everytime you add another instalment to it  :ThumbsUp:
But it is also a bit like George and other very fine craftsmen posting here - all the good words, lines and expressions are used so many times, that it is hard add another good comment and I have no questions to the build right now .... But I can assure you that I enjoy and appreciate your fantastic work  :praise2:
Come to think of it - I do have one now as I can't see much missing at all - are you close to first pop or ?
Online Dave Otto
Re: By Jupiter
« Reply #279 on: March 27, 2019, 12:06:13 AM »
Its always nice to see an update on this beautiful engine.
Very nice work as usual.
Re: By Jupiter
« Reply #280 on: March 27, 2019, 02:41:37 AM »
Mike,
When you talk about a hand crank starter. I have visions of this video of starting a tank.
<a href="http://www.youtube.com/watch?v=ROnb5ouBjNc" target="_blank">http://www.youtube.com/watch?v=ROnb5ouBjNc</a>
I can just picture those poor suckers that had to wind up these cranks to start those Jupiter's.
Oh, every time I see you have posted on the Jupiter I'm on it.
Re: By Jupiter
« Reply #281 on: March 27, 2019, 03:43:53 AM »
Hi Mike,
 Count me in! The  :popcorn: has been harvested so I don’t need ration it for quite awhile at least!
Beautiful work as usual, & nice history tips to go with it
Online steamer
Re: By Jupiter
« Reply #282 on: March 27, 2019, 11:19:33 AM »
I'm definitely following along...just lots of distractions here    Nice work Mike!!
Gotta get a CNC......sweeet!
Offline Jim Nic
  • Buckingham, UK
Re: By Jupiter
« Reply #283 on: March 27, 2019, 11:43:16 AM »
Yet another one here quietly following along in awe.
Re: By Jupiter
« Reply #284 on: March 27, 2019, 08:06:06 PM »
Still watching Mike, with big interest.
