Author Topic: A Tiny 3 cylinder Holt based engine  (Read 3063 times)
« on: October 19, 2017, 09:48:32 PM »
Gentlemen,
Well the engine is finished and running. If you followed the build thread then you know the construction and initial running wasn't without incidents.
Today I took it out on the bench and after a few adjustments it ran quite well but much faster than I had expected. The simple carb was much similar to the one used on the series of Tiny hit and miss engines so with the increased bore diameter of this engine I thought it would run slower.
I took it back down to the shop and installed the original throttling carb then went back out for another try.
While turning it over I started opening the needle valve until it caught and ran. While running I adjusted the ignition timing from the initial setting of about 15 degrees to almost 25 and it smoothed right out.
Here is the video published on Youtube.
Thanks for following the build and commenting along the way.
P.S. I'll have it at the Zanesville engine show this weekend.
<a href="https://www.youtube.com/watch?v=c_KtDdeMepk" target="_blank">http://www.youtube.com/watch?v=c_KtDdeMepk</a>
Re: A Tiny 3 cylinder Holt based engine
« Reply #1 on: October 19, 2017, 09:53:54 PM »
Very nice George!
Congratulations on another beautiful engine added to your collection of work.
Offline 90LX_Notch
    • YouTube Channel
« Reply #2 on: October 19, 2017, 09:57:23 PM »
Perfect.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
« Reply #3 on: October 19, 2017, 10:36:44 PM »
Great job George. Enjoyed the build.
« Reply #4 on: October 19, 2017, 10:42:46 PM »
Another stunning engine George!! As amazing as always.
« Reply #5 on: October 19, 2017, 11:54:59 PM »
Geez, that's beautiful George!  :cartwheel:  Congratulation on a great engine.
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #6 on: October 20, 2017, 12:37:48 AM »
Fantastic engine George!  :ThumbsUp:  :ThumbsUp:  :ThumbsUp:
Thank you for sharing and inspiring!
« Reply #7 on: October 20, 2017, 01:06:42 AM »
Thanks so much everyone for the comments. You don't know how relieved I was when it fired up and kept running. I was really thrilled when I put the throttling carb back on and it responded to the throttle change. Now I can start on the radiator and plumbing.
Offline rudydubya
  • Western Arkansas USA
« Reply #8 on: October 20, 2017, 01:10:25 AM »
Another impressive work of art George.  I always look forward to your projects.
Rudy
Offline Doc
  • USA ND
« Reply #9 on: October 20, 2017, 01:26:23 AM »
Beautiful little engine George!!!  :praise2: :praise2:
« Reply #10 on: October 20, 2017, 03:23:58 AM »
George,
The Holt runs great as can be expected from anything you build. Thanks for sharing the build process with us.
Offline Kim
« Reply #11 on: October 20, 2017, 06:09:11 AM »
That's a beautiful little engine George, and a very nice video to chronicle the build.
Thanks for sharing!
Offline Plani
« Reply #12 on: October 20, 2017, 03:34:07 PM »
This little engine is a beauty George  :praise2: and it's running really well.
Thank you for sharing this build.
Plani
« Reply #13 on: October 29, 2017, 08:13:56 PM »
Hi Georg, again a masterpiece, congratulations.
« Reply #14 on: October 29, 2017, 08:20:35 PM »
Another Masterpiece George!
