Willy, higher up that same page it gives a clue, where it mentions water cutting "as it is called", mentioning it is a propietary mix for a cutting fluid. Also found this statement in a history of machining..."In the 19th century it was not uncommon to use plain water. This was simply a practical expedient to keep the cutter cool, regardless of whether it provided any lubrication at the cutting edge–chip interface. When one considers that high-speed steel (HSS) had not been developed yet, the need to cool the tool becomes all the more apparent. (HSS retains its hardness at high temperatures; other carbon tool steels do not.) An improvement was soda water Sodium_bicarbonate]sodium bicarbonate in water, which better inhibited the rusting of machine slides. These options are generally not used today because more effective alternatives are available.Yes this may be what they were talking about ,But i don't know why they only used water on certain parts ?Willy.
Great stuff Willy, looks and sounds the part Are you intending to run it on steam eventually ? Yes it will be run on steam when it is totally finished with the proper base plate and the governor fitted etc...This was just a tryout with a compressor !!willy
