Author Topic: Chris's Marion 91 Steam Shovel  (Read 351216 times)
Offline Firebird
  • East Midlands UK
« Reply #4140 on: June 20, 2019, 10:11:11 AM »
Hi Chris
Great news on your boiler  :ThumbsUp:
My conway boiler had several leaks and re solders and so did Julians Simplex boiler. With each re heat it seemed to take longer to get the boiler up to soldering temperature, maybe silver solder needs more heat to re melt??
I'll look out for a sievert I think
Anyway great work
Rich
« Reply #4141 on: June 20, 2019, 12:28:03 PM »
Hi Chris, great to see a successful pressure test, another important milestone reached.  Congratulations.
It has been a great tutorial on boiler building, thanks for taking the time to write it up in such detail.
« Reply #4142 on: June 20, 2019, 12:59:20 PM »
Chris--Thank you for the explanation of the fire tubes.---Brian
« Reply #4143 on: June 20, 2019, 01:14:52 PM »
Thanks all, still grinning at the boiler here...!   :cheers:
Rich, the solder does take a bit more to re-melt the second/third time around, I think the alloy mix changes a bit with the copper or something like that.
For those in the US looking for Sievert, this is where I got mine several years ago.
https://www.bestmaterials.com/SearchResult.aspx?KeyWords=sievert
Sievert does make several different lines of torches, not all interchange parts, so I would recommend looking at their catalog/website first:
https://www.sievert.se/products/
It looks like their product line/numbers have changed since I bought mine, not unusual for any manufacturer...
« Reply #4144 on: June 20, 2019, 02:42:58 PM »
Hi Chris, glad to hear the grins are happening re the boiler. Pics looked great.  :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn:
Re Sievert - I had a quote in 2017 from Sievert USA for a 3488-47 torch, neck tube, and 4 sizes of burners small to big, for a job in industry. With Cdn HST tax , delivery, and the dollar exchange at the time, it was close to $750.  :o The firm's owner could not afford that. I went back to using my ancient oxy acetylene torch for the silver soldering, and got along fine with it as always, but for big jobs the heat is too localized. I later found a European-made torch and burner set, similar to older torch models from Sievert, at a firm here in Canada for a fraction of the price on the Sievert quote, bought one, and it works well. However I bought it through a business, they do not sell to private individuals. Just goes to show though that there are lower priced options , with similar capability to Sievert , available with some digging.
« Reply #4145 on: June 20, 2019, 05:24:26 PM »
With the boiler well in hand, time to hold it up - starting in on the front support frame, which on the real machine is a big casting that holds the smokebox end of the boiler up, straddling the middle of the A-frame backstay bars. Laid it out on a chunk of brass left over from the track frames, and chain-drilled around the openings:
That made the initial milling go faster - the center is cut all the way through as is the top arms, the areas around the center will only be taken partway through to leave a center flange.
Then set it up on the roatary table, with the top arc centered on the center of the rotary table. Took a series of cuts to remove the upper part of the bar:
and trimmed that till it fit the boiler closely:
Then started taking down the flange areas - the bar is 1/2" thick, cutting .200" in to leave the .100 flange. The rotary table was handy to do the angled sections too, rotated till they were lined up with the axis of the mill table.
One side done, will turn it over and do the flanges on the other side next, then trim away the sides - they are useful for holding it till then.
« Reply #4146 on: June 20, 2019, 06:32:20 PM »
« Reply #4147 on: June 20, 2019, 07:47:32 PM »
After lunch (uuurrpp) got the other side of the support stand milled in, then started taking off the outer pieces:
and here it is, with a offcut of the boiler shell, ready to drill the mounting holes to hold it to the boiler and to the brace in the main frame:
« Reply #4148 on: June 20, 2019, 08:34:17 PM »
Hello Chris,
Me too,  :ThumbsUp: :ThumbsUp: :ThumbsUp: :NotWorthy:
« Reply #4149 on: June 20, 2019, 10:12:09 PM »
Dog that stand looks outstanding, but hey bud a lot of metal wasted. With your fabrication skills you could of fabed one up......just saying. As always love your work Chris..... :ThumbsUp:
« Reply #4150 on: June 21, 2019, 12:54:27 AM »
I dont look at it as metal wasted, its an offcut from the scrap bin that got used!   ::)     :Lol:
« Reply #4151 on: June 21, 2019, 04:13:42 AM »
Great job on the boiler, sounds like the voice of experience. One down two to go.
« Last Edit: June 22, 2019, 02:05:07 AM by Art K »
« Reply #4152 on: June 21, 2019, 01:08:17 PM »
Great job o  the boiler, sounds like the voice of experience. One down two to go.
Thanks Art!
Two what to go? Not building two more Marions!   :o
  • Raleigh,NC. USA
    • Lauson small engines
« Reply #4153 on: June 21, 2019, 02:39:11 PM »
Looks like you have a boiler, I'll dance with you ! :pinkelephant: :pinkelephant: :cartwheel: :pinkelephant:
Smooth sailing ahead!  Great job.
« Reply #4154 on: June 21, 2019, 03:26:08 PM »
And sailing tomorrow, next rc sub run...
