WOW There's a King's ransom in brass and nuts and bolts in that thing!!Been watching from the beginning, first-time postingRon
I guess by having multiple engines they are a modest size and wont be huge on the finished model if they are at the same scale as the structure.
for the studs am cutting them from 3 foot lengths of threaded rod from McMaster Carr
Quote from: crueby on April 20, 2018, 02:27:18 AMfor the studs am cutting them from 3 foot lengths of threaded rod from McMaster Carr
Quote from: Jo on April 20, 2018, 06:45:26 AMQuote from: crueby on April 20, 2018, 02:27:18 AMfor the studs am cutting them from 3 foot lengths of threaded rod from McMaster Carr Ah. So Jo would rather hand thread both end of 450 studs for the booms. Noted.
Quote from: crueby on April 20, 2018, 01:55:31 PMQuote from: Jo on April 20, 2018, 06:45:26 AMQuote from: crueby on April 20, 2018, 02:27:18 AMfor the studs am cutting them from 3 foot lengths of threaded rod from McMaster Carr Ah. So Jo would rather hand thread both end of 450 studs for the booms. Noted. Been there, done that on the DTC amongst others: I am not a lady who aims for adequate . I only woose like Jason on studs under 8BA (2.2mm = 85 thou dia). Jo
Ah - so 2-56 are .086, thats a whole thou over your limit.
Quote from: crueby on April 20, 2018, 04:22:06 PMAh - so 2-56 are .086, thats a whole thou over your limit. I said under, we don't normally use 9 BA so next is 10BA = 1.7mm = 67thou.Jo
That’s sweet Studley . You’ve mentioned the finish on the chains: are you wanting a state of “as new” or “used in the field” finish? Back in my “industrial period” , while working in paper mills, there were tons of chain used for many tasks. When they came in new, they were a matte grey. Once they were being used, the “rubbing surface” turned an almost polished pewter and the inside of the links became darker and darker. Now mind you, this was the eighties, so, move it back near a hundred years and I would suspect that “new” wasn’t as “matte” as it was then. I did come up with some “ black oxide” treatments when I restored my Cyclone that if not left to fully soak, would produce NOS chain, well close, well I think Super job and will be here until the end ( lack of popcorn, cookies, banter, or death don’t count ) BTW: I just read on the UEU (United Elves Union) website, that they are getting ready to picket Zee’s place. Something about substandard cookies and abuse of power . Keep up the great work Chris Cletus
