I don't want to steer you off into a new track, but at this point I would have to fire the boiler and run all that is finished. Steering would be nice, but to watch all the rest of that machine work will be great. It would take to much discipline to keep me building when that close to a major run.
Oh now that is cute!It’s looking like the next generation elves have got a starter project! I’m sure the head elf will help to keep them on the right track!Looking forward to the build...... Cheers Kerrin
You can do it Chris. You have the right machines for going smaller.FWIW: Small is a relative term. -Bob
One bit of advice- use quality sharp tools if you are going really small. Sharp equals less pressure on a dainty tool which in turn helps reduce breakage. Clear chips regularly. Make sure tools are running true in the spindle of the mill.-Bob
Hi Chris, I wondered whether the broach tool would be adaptable to the smaller engine as soon as I saw your 3D printed model pic. Through the side on the smaller one will likely be far less involved. Good luck with the detail dimensions today. Hope the elves don't get miffed about the thicker webs. Must be an eye-straining job sharpening all those tiny cold chisels every day while they hand carve out a crank from solid ....
