Author Topic: Chris's Marion 91 Steam Shovel  (Read 606994 times)
« Reply #3960 on: May 28, 2019, 07:48:26 PM »
And have the panels cut for second side, still need to drill a few more screw holes and add the faux rivets to it:
Then can start on the hinges and doors...
« Reply #3961 on: May 28, 2019, 08:26:18 PM »
Chris--Have you given any thought to a clear lexan roof? Lexan forms very easily and it's almost a sin to totally hide whats going on inside when all your panels are in place.---Brian
« Reply #3962 on: May 28, 2019, 08:55:09 PM »
The roof will be removable as well as the walls, even easier since it can just set in place. When on display it will most likely have one wall and most of the roof off.
« Reply #3963 on: May 28, 2019, 10:51:20 PM »
The walls and roof are adding a lot of details to this masterpiece Dog. Looking at the pics it could pose as a full size machine with all the added details. Awesome just awesome Chris!...... :praise2:
 :popcornsmall:
« Reply #3964 on: May 29, 2019, 04:11:51 PM »
Thanks Don!
With the wall panels all cut, this morning got started on the fidlly-bits. First took some of the offcuts from the walls and made up the benches for the rear deck and the bin for the front wall - ran a cut halfway through where they needed to bend, and cut the outlines.
Then bent up the tabs to form the rest of the box. The end tabs are a narrower so they dont bump into the sides.
Then started on the hinges. Need a whole bunch of them, so started with a piece of brass sheet, and ran a saw cut halfway through the face down the center to keep the tubing in place during silver soldering. After cleaning that up, used the table saw to slice off each hinge pair. Then used a fine jewelers hand saw to cut the zig-zag through the center to split the pair apart.
After drilling for the mounting rivets and installing on the panels, a pin through the tube will complete the hinge. One down, 19 to go...
« Reply #3965 on: May 29, 2019, 06:57:50 PM »
Woops - missed a photo - here is one of the plates with the tube soldered on before cutting into the hinges...
Made up three of them to get all the hinges out - if longer they would have had a tendancy to bend apart a bit in the center (between the clamps I had on the ends) as the tube and plate heated up, unless they were heated exactly together.
One thing I tried differently this time in silver soldering was the flux. Originally I used Harris White, then switched to Tenacity 5 on the Lombard since it took long heats better. Am running low on that, and could not find a source here in the US, so I looked around and found the Harris Black flux, already mixed to a paste and meant for longer heats like on boilers. So far I like it, no mixing/remixing of the powder like the others, and seems to work about the same. Cleans up nicely with the Sparex pickle. Had not seen it before, wonder if its a newer formula?
« Reply #3966 on: May 29, 2019, 08:47:17 PM »
Like your hinge fab method Chris. It beats my "chase the tiny hinge tube fragment with the torch" method by a long way!
« Reply #3967 on: May 29, 2019, 09:33:43 PM »
And slip rolls are hard to find that will do diameters this small!
Picked up some different shades of red for the outside of the cab walls. Found a decent barn red looking one in the same engine paint as the rest of the model. The walls are going to be red outside, grey inside and grey roof. Marion lettering under the eaves will be white 1/2" tall dry transfer railroad lettering, close match for the way Marion did it in early 1900s.
« Reply #3968 on: May 30, 2019, 05:25:53 PM »
Between making the center cuts on the rest of the hinges (as shown yesterday), I realized that I had not included the patent number plates when I made up the etched plates for the engines and boiler. The patent plates on each side of the frame are still there on the LeRoy shovel,
But the shop number plates, which show the serial number of each machine, are sadly missing and the numbers are unknown. I did find a photo of the plate on a Model 60 machine in Costa Rica:
that shows what they looked like. The outline and remaining bits of the broken edge on the shovel here match this one. I am making up a set of each for the model, but can't decide how to handle the shop number plate. I can make up a number and use that, or maybe take the number and chip most of it off to obscure it like it was vandalized, or maybe break off the bottom section with the number? I don't know what the real number on this machine was, and dont want to document a made up one...   :thinking:
Offline bobh
« Reply #3969 on: May 30, 2019, 06:25:20 PM »
How about your initials and the year?
« Reply #3970 on: May 30, 2019, 06:44:05 PM »
Interesting idea!
« Reply #3971 on: May 30, 2019, 07:30:16 PM »
Chris how about “Model by Chris 20**” fill in the year for shop!
« Reply #3972 on: May 30, 2019, 09:14:52 PM »
Thats a great idea too!
« Reply #3973 on: May 30, 2019, 09:15:51 PM »
While deciding what to put on the shop number plate, got started etching out the patent number plates. Here is the first one etched and a spritz of paint...
« Reply #3974 on: May 30, 2019, 10:03:44 PM »
Hello Chris,
That looks really good and has that "aged" effect.
Have a great day,
