Author Topic: Chris's Marion 91 Steam Shovel  (Read 608791 times)
« Reply #2535 on: November 27, 2018, 08:02:30 PM »
Hello Chris,
As others have noted in the past, some of your photos look like the real (full size) machine. This is a great photo, all it needs is some dirt and grease.
Have a great day,
Thanks Thomas!
Though I'll try not to get TOO good at the weathering, will leave out the racoon poop and such...
Online ddmckee54
« Reply #2536 on: November 27, 2018, 09:46:56 PM »
Yup, building that working scale raccoon so you could get the scale raccoon poop MIGHT just be going a little bit over the edge.
« Reply #2537 on: November 27, 2018, 10:12:08 PM »
:lolb: :ROFL:
Well, its not a raccoon, but we did have this drawing show up last year....
« Reply #2538 on: November 27, 2018, 10:38:53 PM »
Well, different types of 'exhaust' aside, just finished redrawing the valve block for the clutch in Fusion. After taking a close look at the original plans, it was obvious that it needed to be scaled up a little to be practical. The original steam lines into it were only about 1/2" OD, and at 1/16th of that they were a bit more like hypo needles than practical steam tubes on the model. So, redrew the block slightly larger. Should be starting on it tomorrow...
« Reply #2539 on: November 28, 2018, 12:02:52 AM »
Ah...I missed a few posts.
I'm not sure I'm sorry.  ;D
« Reply #2540 on: November 28, 2018, 12:23:11 AM »
Don't be!   :Lol:
« Reply #2541 on: November 28, 2018, 03:45:47 PM »
With all the snow here this past week, some pictures have been floating around. This one should give ideas to those with CNC, looking for mass quantities of parts to mill out...!
And no, this is not from my yard!
« Reply #2542 on: November 28, 2018, 03:52:32 PM »
Started in on the control valve for the hoist clutch this morning. Started with some 1/2" steel bar stock, and milled out the central cavity of the steam chest:
and drilled/tapped the holes to hold the lid, also used to mount to the floor underneath:
Drilled/tapped a M5 hole in the end for the control rod packing gland - this goes in partway, smaller hole for the rod goes through the wall. Some spun teflon tape or valve packing string will be used to seal the rod. The end was milled back to leave a boss around the hole.
The part so far:
Next will be to cut the steam ports on the inside, and drill the holes for the pipes on the outside. The bottom will be thinned down, leaving a boss for the exhaust out the bottom.
« Reply #2543 on: November 28, 2018, 06:58:08 PM »
More work on the valve body - chain drilled the slots for the vavle ports, then used a dental bur in a high speed air handpiece to connect the holes. The passages from the sides were drilled in to meet the slots, and the ends of the holes drilled out to .250 to take the steam pipes. The exhaust port goes out the bottom, to drain below the floor, so the center hole in that slot was drilled all the way through the block.
Then moved over to the lathe to turn the boss on the bottom of the block, centered on the exhaust hole. This boss got a shallow .250 hole to take the end of the drain pipe.
The parts so far, ready to make the valve slider and the packing gland.
« Reply #2544 on: November 28, 2018, 10:59:02 PM »
Hi Chris,
When you say you're using steel for the steam chest, does that mean stainless steel?  I'd think that steel would have a rusting problem when used around steam?
« Reply #2545 on: November 28, 2018, 11:19:11 PM »
Hi Chris,
Yes, I use 303 stainless wherever possible, sometimes have to use tool steel, like for thin flat stock when they don't make it in stainless. This alloy machines very nicely and is reasonably resistant to rust, not as good as other stainless alloys but good enough. I have used it for thru hull fittings on my rc subs with no rust.
Offline Chester
« Reply #2546 on: November 29, 2018, 07:30:10 AM »
Well, seeing as that isn’t your yard, it sure looks like somebody’s elves were enjoying the season!
Offline Firebird
  • East Midlands UK
« Reply #2547 on: November 29, 2018, 08:17:21 AM »
Hi Chris
 :popcornsmall:
Rich
« Reply #2548 on: November 29, 2018, 06:16:50 PM »
Thats gotta be the biggest herd of snowmen I've ever seen!
« Reply #2549 on: November 29, 2018, 06:17:14 PM »
Hi Chris
 :popcornsmall:
Rich
Hi Rich, nice to have you along for the ride!
