I think I have it figured out; those tracks are a fair distance apart and to minimize the turning radius of the shovel, twer it mine, I would want to disconnect one side of the axle to avoid over/under driving one of the tracks. Sorta like a tight turn ( not pivot ) on a Cat.....?????Those parts look huge until you stick your big paws in the picture.. Pete
Yep, I think you're right, Chris. I forgot you'd said the 'rear' tracks would pivot 20*. The 'quick' engagement had to be for assembly purposes...Pete
What would be interesting to know is how it was used. Obviously if it just moved forward it would cut a "slot" with a width determined by the boom's swing.
Sounds like a mutual admiration society kind of thing.--I marvel at what both you guys are doing.---Brian
Chris just posted a couple of pictures that show fairly well how railroad shovels worked, and it's my understanding that's what this thing was originally. You lay the rails up to the work-face, run the shovel up to the face and dig until you can't reach any more. Then you lay more rail and do it over again.It was never meant to turn on a dime, just follow the rails. The curves in those rails had a fairly large radius, even in a construction area. So the angles machined into the tires on the wheels were all the differential that was, and still is, needed by the railroad.Don
