Chris- I've been quietly following this incredible build.I'm located in Skaneateles, NY, not too far from Rochester.Where exactly is the shovel located?Might be a nice drive out sometime.Thanks, Sid
That's funny. I've been to that Jello museum!Thanks, Sid
Yes,I see that. I also visited the Mumford museum years ago with the kids.Had I only known!BTW, I don't think the wiki link works???Sid
Chris...The ratio of bearing width to shaft diameter of say 1.5:1 confirms the absolute mechanical loading that must have been exerted on this dog clutch shaft With respect to the painting of brass, I have seen brass that has been lightly grit blasted with Aluminium Oxide grit....& the result was a greyish surface finish & maintained this with just a few micron surface depth over the depth and poor adhesion of paintWith the actual clutch halves being totally flat/square without any tapered lead-in, would one half of the shaft required to be absolutely stationary, then the opposite coupling half inched around on diameter to ensure smooth engagement of the clutch?Derek
Derek, just went and checked, turns out the grit I have for my airbrush type grit blaster is aluminum oxide, so I ran a test on half of one side of some scrap brass. Interesting effect, slightly gray, looks like a cast surface but still some brassy tint to it. Then taped off half the piece and sprayed on the same paint used on the gears as a comparison of how the paint looks next to and on both shiny and gritted surfaces. Will post pics in the morning...
I broke a tap off this afternoon and couldn't get it out. Very small disaster compared to yours We should have both taken the afternoon off and went drinking!!!
