Author Topic: Chris's Marion 91 Steam Shovel  (Read 330484 times)
« Reply #210 on: November 22, 2017, 07:00:27 PM »
Are you planning to live long enough to make a model of this, or are you going to pass it on to your children and grandchildren----and maybe even your great grandchildren?
 :ROFL:
Hi Brian,
Its definitely going to be a long term project, even by my standards (finished the Shay and Lombard builds in about a year each). I am figuring this one to be about 2 or 3 years, give or take a year - its a SLIGHT help that two of the four steam engines in it are identical, so that will save a few weeks!   :o
I love this kind of project - like you I really enjoy the build, and this one has LOTS of new shapes to figure out how to machine. I am hoping to take things up another notch in the level of detail, always learning new techniques. Given the size of the boiler, I'm not sure if this one will be practical to run on actual steam, or if it will rely on a compressed air line running in. The boiler on the real one  is fairly small compared to the ones on locomotives, and depending what scale I build (something around 1:16 is current guess) the boiler could be too small to run four engines, the main engines are quite large bore/stroke let alone the slew/crowd ones. The NPS guys were very surprised at the size of the boiler, but it obviously was enough for the real machine, it was used for over 40 years.
« Reply #211 on: November 22, 2017, 07:09:36 PM »
This afternoon the casting arrived with the boiler front nameplate from the Lombard Log Hauler up in Maine - the gentleman who made the pattern and cast the one for the restoration of the real one kindly agreed to cast and sell me a bronze copy of it, came out pretty nice.
For size comparison, here is the one on the real machine (someone put a silly model in front of it!)
and here are the spare ones I had photo-etched for the model:
And here is the casting he did for me, with the photo-etched ones in the lower left for scale, ready for some final cleanup and painting:
The back has the name of the museum, nice touch:
So, after some casting fondling (hope I don't have to send it to Jo for some professional casting-fondling time), I'll get the edges filed/sanded smooth where the gates were, get it wire brushed clean and painted. Should look wonderful with the model!
 :cartwheel:
« Last Edit: June 06, 2018, 07:09:38 PM by crueby »
« Reply #212 on: November 22, 2017, 07:35:26 PM »
Very nice Chris, would it help to flycut the top of the letters to make them stand out more?
« Reply #213 on: November 22, 2017, 07:57:14 PM »
Hmmm, maybe.... the lug on the back is tapered slightly, but I could drill/tap it for a better hold. I'll probably start with some sanding and see what it looks like. The original was painted black with the tops of the rings/letters painted gold, have not decided whether to do the same or to leave it bronze. Though, now that you mention it, if the relieved surfaces are still the rough, and the tops taken smooth and polished, the bronze color would pop... Could just clear lacquer it to keep it shiny...
 :thinking:
« Reply #214 on: November 22, 2017, 10:01:57 PM »
Rear track frames now done too - after making the ones for the front, naturally the second (similar) set went quicker.
« Last Edit: June 06, 2018, 07:09:54 PM by crueby »
« Reply #215 on: November 22, 2017, 11:06:16 PM »
That nameplate casting looks great, Chris!  That's a big hunk of bronze!
Can't wait to see how you finish it.  I'm voting for black background and polish up the letters - I think that would look very sharp!  But its your casting, and you get the only vote that counts  ;)
« Reply #216 on: November 23, 2017, 02:27:56 AM »
I was looking at the photos and measurements of the steering engine, and it looks like I got a break, it appears to be identical to the slew and crowd engines, just scaled down by a third and put on a vertical mounting bracket. So, that will save a lot of drawing time, just need to scale a copy and draw the new bracket and gear covers. Won't save much time actually building it, but that's fine.
« Reply #217 on: November 23, 2017, 02:43:17 AM »
I figure that the whole thing needs a good wire brushing to remove the sand residue,  the outer rings and tops of the letters will get filed and sanded smooth, and there are some of the inner edges that need some detailing. The background will stay rough as cast. Then probably a soak in citric acid to brighten it all up and clean off any oils. At that point I will decide whether to paint it black with gold tops like the original, or give it a clear lacquer coat, which could look really nice, have to see what the bronze comes up like. Either way, it's a great piece.
Offline Stuart
  • Tilchestune UK
« Reply #218 on: November 23, 2017, 07:36:12 AM »
Danger will Robinson
Unless your citric is clean /new it could plate it pink ( copper in the acid )
Likewise if that cast has some free copper ions it will do the same
Test it first on the spru
I recon the build will take about 2 years
My loco builds for full scale in 5 inch gauge was 5 to 6 years , one guy at the club took 21 for his
Great work with f360
« Reply #219 on: November 23, 2017, 01:33:09 PM »
Oh yes, I've gotten the color cast from used pickle solution before! I have a fresh bag of citric acid crystals and will try it with that. If I don't like the color it comes out, paint is always the fallback.
« Reply #220 on: November 23, 2017, 04:00:56 PM »
As I found yesterday, the steering engine is a scaled down version of the slew/crowd engines remounted on a vertical base, so it was quick to copy/scale in Fusion, here it is:
and where it sits next to the boiler backhead. The spur gear on the output shaft engages a larger gear that turns a shaft that runs up to the steering box in front of the rear tracks. That box has a worm gear to turn the motion 90 degrees across the frames, turning a really long acme threaded rod that moves the front bar of the rear track assembly back and forth, steering the machine.
« Last Edit: June 06, 2018, 07:10:18 PM by crueby »
« Reply #221 on: November 24, 2017, 08:01:50 PM »
Not going to be too much to show the next day or so, I've started sorting through all the pictures from up underneath the main frame, tracing which control lever goes to which control rod, and where that leads. Lots of clevises, control horns, counterwieghts, cobwebs, and birds nests to diagram. So far I have the dog clutch, throttles for hoist, crowd, and steering, and the hoist clutch figured out. Still need to trace the reversing link on the hoist, throttle for the swing engine, and the hoist brake linkages.
Lots of breaks for cookies and leftovers!
« Reply #222 on: November 24, 2017, 08:22:20 PM »
Hello Chris,
All these 3-D drawings and details are incredible. Most impressive work on your part.
Have a great day,
Offline J.L.
« Reply #223 on: November 24, 2017, 08:27:41 PM »
Hi Chris,
This work is beyond belief. Truly a labour of love.
You must have spent hours of research before even beginning to  physicallly represent the parts on the computer.
A most fascinating project to follow.  :ThumbsUp:
Cheers...John
« Reply #224 on: November 24, 2017, 08:50:04 PM »
Thanks John/Thomas!  I've been researching this shovel since last spring, digging (  :Lol: ) into old photos, videos, lots of time reading the patents from the Marion company and others (get lots of mechanism details that way). After making contact with the folks at the historical society I was able to get inside access to the surviving shovel near here, which filled in SO many details. I think I am within a week of finishing up the 3d drawing, and then can start generating the 2D blueprints from that.
