This past weekend at Cabin Fever, I met an saw Doug Kelly's engines. Just outstanding work!I wondering what you are going to use for the cylinders? Are you going to bore material to size or I think I've heard mentioned using honed, hydraulic cylinder tubing. I cant remember if someone mentioned it at the show??Coming along nicely, BTW!Thanks, Sid
I think "on my side of the pond" it's 12L14 leaded steal.
How have you guys found 12L14 for corrosion over time in a model engine? General parts I've made from 12L14 around the shop can show rust flecks and I live in a very dry part of the world. Gnerally I blacken them but that's not possible for a cylinder liner. I love machining the stuff & considered it for my radial engine but, particularly because its methanol glow fuel, opted for cast iron. Not sure it will be a noticeable improvement but CI is whats called for in the plans & even old school commercial glow engines used CI it before hard chroming came in.
