Author Topic: Thread angle  (Read 2694 times)
Offline Firebird
  • East Midlands UK
Thread angle
« on: October 08, 2017, 02:48:29 PM »
Hi
I need to make a number of fittings (brass mainly) for my Conway loco.
I have tried a die in the tail stock holder but I'm not really happy with the quality.
I'm going to try screw cutting, 40tpi and 32tpi
Does anyone know what the angle of the thread is? I have looked but can only find general info/tapping hole size etc.
Rich
Offline Stuart
  • Tilchestune UK
Re: Thread angle
« Reply #1 on: October 08, 2017, 02:55:11 PM »
It’s the same as BSW 55degrees
Hope that helps
IMHO the quality of the ME dies is not that great
I look after my HSS set and help the dies out by single pointing
Offline jadge
  • Cambridge, UK
Re: Thread angle
« Reply #2 on: October 08, 2017, 02:58:58 PM »
If you're referring to the ME range of threads then they're Whitworth form, so the included angle is 55°. Can't say I've ever cut a 40tpi thread, but I've screwcut dozens of 32tpi threads ranging from 1/4" diameter to over 3". I'm too idle to grind a HSS tool so I use a full form 32tpi Whitworth insert.
Andrew
Offline Firebird
  • East Midlands UK
Re: Thread angle
« Reply #3 on: October 08, 2017, 03:01:28 PM »
Hi Stuart and Andrew
Yes that helps  :ThumbsUp:
Do you know of a chart that lists thread depth etc.
Rich
Offline Stuart
  • Tilchestune UK
Re: Thread angle
« Reply #4 on: October 08, 2017, 03:09:36 PM »
If you do not mind mucky thumb prints
Pm me your email I will send you a pdf of the info
Offline jadge
  • Cambridge, UK
Re: Thread angle
« Reply #5 on: October 08, 2017, 03:17:48 PM »
Conveniently for 32tpi Whitworth the thread depth is 20 thou, if you ignore the odd one hundredth of a thou. I use the chart in an old Machinery's Handbook.
Andrew
Offline Stuart
  • Tilchestune UK
Re: Thread angle
« Reply #6 on: October 08, 2017, 03:23:45 PM »
Rich
The files are to large to post please PM as above
Offline Firebird
  • East Midlands UK
Re: Thread angle
« Reply #7 on: October 08, 2017, 03:25:54 PM »
Hi Stuart
PM sent
Rich
Offline Dan Rowe
  • Dripping Springs TX USA
Re: Thread angle
« Reply #8 on: October 08, 2017, 03:29:13 PM »
« Last Edit: October 08, 2017, 03:34:32 PM by Dan Rowe »
ShaylocoDan
Offline Stuart
  • Tilchestune UK
Re: Thread angle
« Reply #9 on: October 08, 2017, 03:32:03 PM »
On its way
Offline Firebird
  • East Midlands UK
Re: Thread angle
« Reply #10 on: October 08, 2017, 03:51:17 PM »
Hi
Thanks Dan  :ThumbsUp:
Stuart, recieved and printed  :cheers:
Rich
Offline Stuart
  • Tilchestune UK
Re: Thread angle
« Reply #11 on: October 08, 2017, 04:00:00 PM »
Rich
Sorry for the muck but they are my WS chart and do get used  :happyreader:
But mostly I use BA for fixing 8 BA and less ,with a small amount of metric but I make those as the standard metric heads are to out of scale so Jo will be happy nuts and studs are made
Re: Thread angle
« Reply #12 on: October 08, 2017, 09:57:59 PM »
If you're looking for the taper angle rather than the thread form angle, NPT has a taper of 1 degree, 47 minutes.
