Author Topic: Lathe turning tool holders from China  (Read 4296 times)
Offline Mike R
  • Ottawa, ON
« on: October 04, 2017, 03:13:07 AM »
I needed some tooling to support my newly updated Compact 5 CNC lathe (uses 10mm or 3/8" turning tools).
I have bought recently several turning tool holders from Banggood.com in China and I have been pleasantly surprised by the quality of the items received.
80 degree insert tool holders for left, right, straight and boring bar;  threading insert holder, parting insert holder (1.5mm width) and lots of inserts.
The cost of these items has been remarkably low ($10-$15 individually priced and cheaper per piece as a set), with the small inserts being ~$1 to $2 each.
Fit and finish are good, and the tools hold the inserts tightly without slop, so the inserts can be replaced repeatably without worry of the offset changing.
I have already modified the threading holder to fit the lathe - I don't think I would have done that to a $60 + tool holder.
Also, I must say my shopping experience with Banggood.com has been good.  They have replaced items I did not receive and refunded me when some small 6mm milling cutters showed up as 4 flute when I had ordered and expected 3 flutes (I got to keep the 4 flute cutters - 5 @ $2 each).
The only negative I have had is strictly a thing for Canadians to be aware of.  The cheap shipping means it arrives in Canada and is sent to a warehouse to be processed by Canada customs.  That takes forever and a day - I waited 4 months for 1 item to show up and that is considered "normal"!  However, paying for premium shipping does ensure it shows up in reasonable amount of time (~ 1 week) - best done by bundling a few items together so that shipping isn't more than the cost of the items.  Don't bother paying for "tracking" on the slow/free shipping method to Canada - it only works until it leaves China... :facepalm:
Other than that I only have positive things to say about the products themselves.
Offline Richard Laslett
  • Jr. member
Re: Lathe turning tool holders from China
« Reply #1 on: January 03, 2018, 05:54:52 AM »
I have found their 0.5 mod gear cutters very good as well. 10 days from ordering to receiving in Sth Australia.
« Reply #2 on: January 03, 2018, 07:30:54 AM »
Mike how easy was it to machine the threading tool holder? I have heard that some of the tools via Bangood etc are a bit soft, a good tool holder will be difficult to cut with carbide.
Offline Mike R
  • Ottawa, ON
« Reply #3 on: January 03, 2018, 01:20:51 PM »
Jason,
They are not super hard,  I was able to cut (with some difficulty) with a hacksaw the back end off one of the 10mm holders to use on my little Emco.  Hasn't been a problem for me though as the rest of the machine is as rigid as a noodle and the tool ends up clamped very close to the tip, so I haven't noticed and flex issue in the tool.  The larger ones I didn't modify but I use them rather lightly so again, no complaints, maybe not the best but good enough for me.
Offline Andy
  • Hitchin, Herts, Uk
« Reply #4 on: January 03, 2018, 04:48:29 PM »
The ones I purchased were hard. Tried with carbide and ended up grinding the first one I did. I just grind them now   :hammerbash:
