Well I'm pleased to say I've now got a bit further on and things are starting to take shape so I thought I'd add a progress update.
I decided to take the base plate next, it's not rocket science but does involve cutting a rounded profile concentric with the cylinder and adding a decorative radiussed detail all round, I've never done it before so I wasn't really looking forward to it.
The first bit is fairly straightforward - cut some steel plate to size, drill holes for the columns etc then add the radiussed edge. I bought a 2mm radius rounding mill at a decent price and it seems to do the job.
Next it's the dreaded rotary table to cut the semicircular front arc. I struggled to hold the part to allow a full 180
o swing so in the end I bolted it to a scrap bar
A final check to see it is still centred after tightening down.
Although I didn't show making it I did make a bottom cylinder cover that isn't in the original model, so next job was to cut a 12mm recess at the cylinder centre line to accept the raised boss on the cover underside. It's probably a bit of overkill but it's to aid drilling mounting holes and help to locate the cylinder accurately later.
90 turns of the rotary table handle and the cylinder mounting holes are done.
I wasn't sure of the best way to tackle cutting the front arc but settled on drilling 2 6mm dia holes where the arc will meet with the straight.
Just a case of join the dots now
Then add the decorative radius using the rounding mill
It's not brilliant but once the swarf is wiped away the cut isn't as bad as it looks. The only slight snag is I can't finish the cut on the 2 straight sides without fouling the mounting hardware
After a night to think it over I remounted it and after a few cautious cuts arrived at this.
There is a bit of a dwell mark but I'm reasonably pleased - I think a bit of emery and a lick of paint and things should be ok
With the base done it's onto the flywheel, I haven't been able to get a curved spoke casting as I would have liked so I opted for a Lady Stephanie casting.
It's the first flywheel casting I've turned so wasn't sure what to expect, it seemed to me to be hard work and had numerous deep cavities. This isn't a very good photo but it's possible to see that even with a thin rim I still need to take more off
Being a bit miffed with the wheel I didn't take as many photos as I would have liked but in the end it turned out ok and that now takes me to this point.
It's starting to look like an engine and there isn't really a lot more to do. Hopefully I'll get the column capitals done in the next day or 2 then it's on to the piston / crosshead assembly.
My boiler should be ready to collect in 2 - 3 weeks and I'm reckoning the engine will be completed about the same time
Peter
