Author Topic: Building a Muncaster entablature engine  (Read 23039 times)
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
Re: Building a Muncaster entablature engine
« Reply #135 on: June 24, 2018, 10:16:27 PM »
Brian, I have thought about the point you make as at the moment I'm just using fairly basic DSLR with an in built flash but it's far from ideal. A bit of secondary lighting is something I'll experiment with.
I bought a tablet computer a few days ago it might be worth seeing how that photographs under different lighting situations.
« Reply #136 on: June 24, 2018, 10:39:01 PM »
I dont use the flash on my camera for the build pics, too many highlights as he says. Even the direct lighting from my spotlights I work under can overwhelm the image, usually I aim them off to the side a bit and just use the reflected light.
Offline Gas_mantle
  • North Yorks - UK.
« Reply #137 on: June 24, 2018, 10:47:47 PM »
My lathe and mill are in a fairly confined area where the natural lighting isn't great so I tend to use the flash but I take the point it's far from ideal. I find that a flash on shiny metal often makes what is a good finish look dreadful.
You may have noticed my 'finished result' photos are usually taken outside where the lighting makes my dodgy machining look incredible  ;)
