Author Topic: A Robinson from rejects.  (Read 73564 times)
Offline Zephyrin
  • near Paris, France
Re: A Robinson from rejects.
« Reply #45 on: October 03, 2017, 10:39:10 AM »
Thanks for documenting the die and the moulding process, lot to learn.
A nice and interesting engine, even if the gears are not visible while running !
Offline Alyn Foundry
« Reply #46 on: October 03, 2017, 11:37:26 AM »
Hi Graham, I've been redrawing up the X Type drawings in Alibre..... There are a few what we term "features" in the drawings  ::)
Just finished drawing up the Ignition tube and Chimney but still not sure how it works  :headscratch:
Hi Jo.
Hmmm... Alibra.... Nothing to do with Tee and Set squares then?   :) How easy it is these days!
" Features " ? Could you elaborate please?
Hot tube ignition was considered to be the most reliable form during the early years of engine manufacture, particularly with engines that used a gaseous fuel.
Jason has pretty much summed up the MO.
As time progressed and manufacturers began increasing compression pressures to increase power output it soon became apparent that " preignition " was a real issue. Some makers employed mechanically actuated valves to open the ignition tube at the right time. By this time " electric " ignition had become far more reliable and began to replace the heated tube method.
Thought of the day....
" Chauffeur " ?? Goes right back to the early IC engine era.
Cheers Graham.
« Reply #47 on: October 03, 2017, 11:55:52 AM »
Hi Zephyrin.
You're welcome.
After the success of the cast gear for the Robinson engine I started to look at other " gravity cast " items.
I made many Steel moulds for both the big end and main bearings for my Gardner model, the original, later engines used " Babbit " metal, the Zinc looking very authentic indeed! The real beauty is that by factoring the shrinkage the outside of your part will fit without any further machining.
Being such a low melting point metal it's easy to create intricate castings with fantastic detail.
Cheers Graham.
« Reply #48 on: October 03, 2017, 01:10:15 PM »
A couple of measurements that when drawn to dimension don't look like your original drawing  ::).... Measurements crossed out and not replaced and the use of 1/6th as an imperial measurement fraction :Lol:
When I have finished putting the bits together I will lay them out in 2D and attach them to the thread, in nice modern measurements  ;D. Yes I know I have invented unique measurements for all those "as cast" dimensions which may be wrong  ;)
« Reply #49 on: October 03, 2017, 01:19:42 PM »
Why not wait until you have the castings in your hand then you can take sizes off of the actual part rather than make things up?
« Reply #50 on: October 03, 2017, 01:24:25 PM »
That would mean waiting until a week before I may have to return to work  :facepalm: :hellno:
« Reply #51 on: October 03, 2017, 01:27:03 PM »
You could fill in the time completing the Otto drawings that you were going to do while off sick :LittleDevil:
« Reply #52 on: October 03, 2017, 01:29:04 PM »
There are four more items left to finish those and there is also the Scorpion drawings underway.
« Reply #53 on: October 03, 2017, 02:23:58 PM »
Hi Jo.
I'm looking forward to seeing the fruit of your labours.
I'll be going back to the workshop in a few days to continue my build but I'm beginning to think I should have used a couple of plurals in the title of this thread!   ;) I have a feeling that there will be a few more contributors joining us come November.
The Robinson is really quite a simple engine to build, in fact one of my former customers built his with just a Drummond roundbed lathe and a pillar drill!
Cheers Graham.
« Reply #54 on: October 05, 2017, 05:04:30 PM »
Look what I just found  :naughty:
Now this Sphinx seems to have my name on it  :mischief:
« Reply #55 on: October 05, 2017, 05:47:01 PM »
 :lolb:
Look at the highly professional date change and price increase !
My goodness, the year our youngest was born.
I hope you're joking Jo? But I might just have the last laugh.... >:D
Need any help in the garden?? Perhaps a Gardner....  :naughty:
Cheers Graham.
« Reply #56 on: October 05, 2017, 06:32:17 PM »
I am looking to employ a gardener due to :old:
But I still think there are not enough Sphinx's in the world  ;)
« Reply #57 on: October 05, 2017, 08:11:28 PM »
Well....
Here's the very first one, slightly modded over time.
<a href="https://www.youtube.com/watch?v=0pxNlFMT24I" target="_blank">http://www.youtube.com/watch?v=0pxNlFMT24I</a>
Cheers Graham.
« Reply #58 on: October 05, 2017, 08:31:34 PM »
Graham, is that a burner "ring" at the bottom of the hot tube?
On the valve I assume the exhaust seat is machined into the right hand end and the inlet valve seats on the end of the screw in brass part to the left.
« Reply #59 on: October 05, 2017, 09:13:47 PM »
Hi Jason.
Right on the nose !!   :)
Over the years I learned a few tricks.... The gas ring is quite simple, a hollowed out " doughnut " with a press fitted Brass disc with lots of holes. The trick is the gas/air mix...
Into the side of the burner ring is a passageway that connects to a proprietary made gas burner like Sievert etc. This ensures a perfect mix to burn from the ring !!
The side mounted exhaust valve chest is loosely based on the Robinson, but with twist, I decided to put the air/gas valve into the other end instead of a separate/different location.
This was my second freelance design so simplicity of build was still paramount. As we learned so we grew.
Cheers Graham.
