Author Topic: A Robinson from rejects.  (Read 73426 times)
Offline Alyn Foundry
Re: A Robinson from rejects.
« Reply #420 on: May 21, 2020, 12:22:39 PM »
A few days later.
Only recently did we discoverer that Robinson engines of this era were fitted with " wick feed " cylinder lubrication....
A run is imminent, just waiting on Viton " O " ring and a Sievert 8842 burner to arrive.
Cheers Graham.
« Reply #421 on: May 21, 2020, 12:37:00 PM »
 8)
« Reply #422 on: May 21, 2020, 12:48:19 PM »
8)
Thanks Jo.  :)
For those that might be interested, here's the lubricator and a " fag packet " drawing.
Cheers Graham.
« Reply #423 on: May 21, 2020, 01:11:37 PM »
Looks good, any progress on your projects or are they distancing you from the workshop?
PS don't let Jo catch you using metric and imperial on the same drawing :mischief: Will you have a vertical tube and wick or just let the oil run down a small hole?
« Reply #424 on: May 21, 2020, 02:16:53 PM »
Thanks Jason.   :)
Well.... I can't be blamed for the mixture, in fact the guy apologised for the mix himself.
The original had a vertical tube within so as to use the " wick " effect rather than a blocked flow.
As for the " other " projects I'm in the midst of making a fixture for cutting the missing skew gears of 6&12 tooth @ 6 DP as I write. Just received a 6mm Carbide ball cutter and am negotiating for a gear cutter too.
Cheers Graham.
« Reply #425 on: May 21, 2020, 06:02:13 PM »
Looking good  :praise2:  :praise2: I do like the blue  :ThumbsUp:  :wine1:
« Reply #426 on: May 23, 2020, 12:04:48 PM »
Thanks Roger.
Alan used what remained of the paint left over from his earlier Robinson project.
<a href="https://www.youtube.com/watch?v=5VW0Zi-f7g0" target="_blank">http://www.youtube.com/watch?v=5VW0Zi-f7g0</a>
Meanwhile....
My order for the gas burners arrived this morning. Definitely a lot dearer than they used to be but not as
" heavy " as eBay. Prompt service too. They seem to have gone a little overboard on the packaging though!
A little box would be more " environmentally " friendly....
Cheers Graham.
« Reply #427 on: May 23, 2020, 12:11:22 PM »
 8)
Another Blue engine   :)
« Reply #428 on: May 23, 2020, 01:30:08 PM »
Looks like the boys have a few more engine projects coming if they are going to use all those burners
« Reply #429 on: May 23, 2020, 01:59:07 PM »
Not really Jason.
Mathew has got about 50% of his Gardner done and I bought one for stock. I'm sure I mentioned a ways back that they are prone to " clogging " from the " heavy ends " that reside in the bottom of Propane gas cylinders?
Cheers Graham.
« Reply #430 on: May 23, 2020, 03:37:03 PM »
Yes you did when I felt mine was not heating the tube very well.
« Reply #431 on: May 25, 2020, 12:04:40 PM »
From the " historical " perspective....
Courtesy, Geoff Challinor, Anson Engine museum.
Look at the size of the 10 HP Oblique....   :o
« Reply #432 on: May 25, 2020, 01:26:42 PM »
Did the larger ones vary much visually or were they more or less scaled up engines, that would chop a lot of chips!
« Reply #433 on: May 25, 2020, 06:11:40 PM »
Hi Jason.
Attached picture, courtesy Geoff Challinor.
This is probably the largest, pictorial survivor. Could be a size " Z " or a size " A "
The picture was handed down from the grandfather who worked there. We're uncertain as to why the plate is stamped size " X " the engine appears to be unpainted and the crank guard carrying the magneto is very probably a much later addition.
As you can see the size is just scaled up to accommodate the increase in horsepower.
Don't forget that the internal combustion engine ( Robinson's included ) did just about everything before electricity and the electric motor took over.
Cheers Graham.
« Reply #434 on: June 02, 2020, 04:48:07 PM »
  Hmmm, a likely candidate for....
    " JASONIFICATION "
          Watch this space.
