Author Topic: Need help with sealing boiler leaks  (Read 1582 times)
Offline AOG
« on: September 05, 2017, 12:52:44 AM »
I have been building a PMR vertical boiler as part of my steam powered iPhone charger project. I have gotten to the point where the boiler is soldered but I have a bunch of pin hole leaks that I can't get rid of. Every time I solder up a leak I get one somewhere else. Advice would be greatly appreciated.
Thanks
Tony
« Last Edit: September 05, 2017, 01:46:34 AM by AOG »
Re: Need help with sealing boiler leaks
« Reply #1 on: September 05, 2017, 07:25:16 AM »
Find yourself a pin punch and gently use that with a small hammer to tap the offending pin holes closed.
Offline AOG
« Reply #2 on: September 05, 2017, 11:49:29 AM »
Thanks Jo, i'll give it a try.
Tony
Offline Stuart
  • Tilchestune UK
« Reply #3 on: September 05, 2017, 12:25:04 PM »
Or just steam it up
Your test has proved the structure, often the small pin holes close up with heat and the lime in the water
It’s a old time fact it will not hold water but it holds steam
