Author Topic: Buzz Coil Condenser/capacitor  (Read 7535 times)
« on: July 20, 2012, 03:28:13 PM »
I have got most of the parts to make a buzz coil - KW point and a suitable coil, just wondering what size condenser/capacitor to use.
There seems to be very little on the net about whats inside the boxes but plenty on how to wire them to the engine, best I could find was this article . The engine has a suitable timer with facility to advance & retard the spark, it will be 6volt and uses a CM-6 10mm plug.
Bluechip
Re: Buzz Coil Condenser/capacitor
« Reply #1 on: July 20, 2012, 03:50:39 PM »
Jason
Typically they  were .22uF or 220nF whichever way you prefer.
Have seen .1uF 100nF.
They need to be of a high voltage rating. They live in a nasty environment.
I would suggest 600VDC at least.
Never tried it, but I would think a suppression capacitor with the X1 spec. would be OK.
Suppression caps. are tolerant to voltage spikes. They have to be. Self-healing PP often.
Want a link ??
EDIT Have one anyway, they're cheap enough ... this sort of thing ...
http://cpc.farnell.com/vishay-bc-components/bfc233610224/capacitor-class-x1-0-22uf/dp/CA07149
« Last Edit: July 20, 2012, 03:59:05 PM by Bluechip »
« Reply #2 on: July 20, 2012, 04:05:45 PM »
Thanks Dave, I think I can afford one of those, my other thought was a condenser from a small briggs & stratton or similar.
Bluechip
« Reply #3 on: July 20, 2012, 04:16:08 PM »
Not with the postage ....  ;D
I see no reason why they should not be the same as the cap. fitted to any 'points/coil' jobby.
Try your local car bits outfit.
No doubt they will be more expensive, but maybe a better deal overall.
I've got some of the things anyway, I think. Will have a severe shufti in my heap.
PM me your addy, and I'll slap a few in a jiffy bag if you want.
