I received the PMR Boiler today.
Looks like a very fun project.
It's much bigger than I had thought. The boiler pipe alone is 6.5".
You read the dimensions...but seeing it in real life is different.
Here's a shot of the box and contents.
Here's a shot of the separate parts. The baggie at top right was stuff in the boiler tube.
Inside the baggie were 4 more baggies.
One containing a pre-made safety valve.
One containing the parts for the water level tube.
One containing some solder and liquid flux (zinc chloride and hydrochloric acid).
One containing the rivets and many other odds and ends (including a finishing nail).
Two large sheets of instructions.
I won't start on this for a while. Too much of a distraction from Spinster. (The Dynamo on the other hand looks fun and quick.)
When I do start this, I'll start a thread and repost the pictures.
I do worry a bit about the size of the parts. I just have a mini-lathe. But I suspect others have done this on a similar lathe. Should be okay.
Looks like a great beginner's project and to Marv's point reduces the anxiety of building something that's certainly much more than a toy.
I also got the PMR Dynamo the other day. I won't post the pictures of it yet. There's not that much to it and Marv's shot below pretty much tells the story. I'll have pictures of the contents when I start that thread.
