Author Topic: My boss is buying me a new toy  (Read 10108 times)
Offline Tin Falcon
  • Down Jersey USA
Re: My boss is buying me a new toy
« Reply #45 on: August 19, 2017, 12:23:03 AM »
Looks more like a conference room or office from the picture.
With an overhead garage door. !!
Tin
« Reply #46 on: August 19, 2017, 12:24:08 AM »
It was the vertical blinds in the first picture that faked me out Tin, I hadn't' see the second picture till just now :)
« Reply #47 on: August 19, 2017, 12:25:34 AM »
Derbyshire 750
« Reply #48 on: August 19, 2017, 01:09:02 AM »
Nice looking machines Dave!
Did you get the full enclosure for the mill?
« Reply #49 on: August 19, 2017, 01:11:34 AM »
No I didn't   We'll be cutting very small plastic parts mostly.   and I wanted to spend the 1500 on something else, so no flood coolant either....I may live to regret that...but then again....we can add it later
Offline Walsheng
  • Norfolk, MA
    • Walsh Engineering
« Reply #50 on: August 19, 2017, 02:53:59 AM »
Until I set up the flood cooling on my machine I used a Micro Drop oiler and it worked pretty well.  I was machining mostly aluminum and plastic, though a good amount of SS as well.
I still use the Micro Drop on the manual mills and the lathes but use flood on everything on the 1100.
« Reply #51 on: August 19, 2017, 12:45:48 PM »
I discussed the application with Tormach, and they said the mist lube system should be more than sufficient for plastic, which will be most of what we work....Everything else gets lubed the old fashioned way I guess.
Offline Mosey
  • Rosemont, New Jersey, USA
« Reply #52 on: August 21, 2017, 03:17:08 PM »
Derbyshire 750
Thats pretty, Dave
Mosey
« Reply #53 on: August 21, 2017, 11:19:32 PM »
Even cutting plastic you'll probably get escapees on the floor.   Some shields on each end of the table will help.
Offline steamboatmodel
« Reply #54 on: August 23, 2017, 01:49:07 AM »
For test runs of programs when I was in collage learning CNC we used Styrofoam, a lot easier on the tools and nerves with a new program especially a CAM one where you did not do the g code. Another place where we did control panels out of aluminum or steel we used Plexiglas, you could put the test peace over the drawing and major mistakes jumped out at you.
Gerald.
« Reply #55 on: August 23, 2017, 02:39:12 AM »
Well she's been running for 2 days now, I cut my first "part" yesterday.   Today I spent the day trying to get CAM proficient....it took all day to do some things that now I can do in about 15 minutes...but that's the learning curve isn't it?
I have some plans to cut real parts Thursday...still waiting on some tooling, and indicators ect.   This place only had a drill press and a fist full of worn out drills.....pitiful.
