Author Topic: Completed twin cylinder steam engine  (Read 3149 times)
« on: July 29, 2017, 03:56:51 PM »
Hey everyone,
I have completed building my original design twin cylinder steam engine and attaching a short video of it in action. It is running on 2-psi air not steam, but I am most pleased with the way this build has turned out. Lots of good help and advice received from the Forum members during the construction process.
Thanks everyone,
Video link:
<a href="https://www.youtube.com/watch?v=Qi7YcN7qZc0" target="_blank">http://www.youtube.com/watch?v=Qi7YcN7qZc0</a>
Offline 90LX_Notch
    • YouTube Channel
Re: Completed twin cylinder steam engine
« Reply #1 on: July 30, 2017, 12:24:28 AM »
It really runs very well Thomas.  The sound is sweet.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
« Reply #2 on: July 30, 2017, 12:54:41 AM »
-Bob
Thank you Bob
« Reply #3 on: July 30, 2017, 01:11:43 AM »
Great runner Thomas.  Love the sound also.
Offline Zephyrin
  • near Paris, France
« Reply #4 on: July 30, 2017, 09:34:04 AM »
Nice engine, good  work, congrats !
but you don't give us lot of details on it, i.e. on the piston valve design...
« Reply #5 on: July 30, 2017, 10:55:06 AM »
Thank you Vince, a friend gave me the idea of adding the sound.
« Reply #6 on: July 30, 2017, 11:06:40 AM »
Hello Zephyrin,
The engine specifications are:
Style: Steam Engine, Simplex, open bottom, open column
Number of cylinders: Two, aluminum with brass insert liners
Bore: 1-inch
Stroke: .875 - inch
Pistons: Aluminum, with 3 oil grooves, machined from round bar
Connecting Rods: aluminum, machined from flat bar
Valves: One per cylinder, machined from 1/4" brass round rod, double opening, spring loaded
Valve Chambers: One per cylinder, vertical, single 1/4" bore, machined from aluminum flat bar
Cam: Brass 2, eccentric lobes, mounted on crankshaft, adjustable timing
Head: Aluminum with internal steam and exhaust portals, machined from flat bar
Bottom Plate: Aluminum, machined from flat bar
Crankshaft: Brass, 180 degree offset each journal, mounted on s/s ball bearings
End Plates and Base: Aluminum flat bar, machined to shape
Flywheel: Cast brass modified with a longer center hub.
Steam and Exhaust plumbing: brass pipe and fittings
Hardware: stainless
I have a build thread in Your Own Design titled Travis Steam Engine No.4 with photos and videos.
Thank you,
« Reply #7 on: July 31, 2017, 01:05:12 PM »
Hello to all,
I have created (I think, this darn internet stuff gets me) a small website to link the videos of all my engines built to date.
NOTE: 07/31/17 the  .pdf format of the free plans to build Steam Engine No.4 are now loaded on one page as a file attachment. If you need any more information please let me know.
Here is the link:
https://sites.google.com/site/yeolesteamdude/
Thanks everyone,
« Last Edit: July 31, 2017, 04:05:42 PM by Ye-Ole Steam Dude »
Offline wagnmkr
  • Lindsay, Ontario, Canada
« Reply #8 on: July 31, 2017, 04:27:31 PM »
Got the plans ... Thanks Thomas
Tom
« Reply #9 on: July 31, 2017, 05:09:00 PM »
Tom
Hey Tom,
Hope you keep me up to date on the build. If you have any questions contact me here or via my personal email.
Have a great day,
Offline wagnmkr
« Reply #10 on: July 31, 2017, 10:47:05 PM »
It will be a bit before I can start anything. I am slowly recovering from some cracked and broken ribs. Once that is better I should be able to get at it.
Tom
« Reply #11 on: July 31, 2017, 11:02:27 PM »
Thomas, I have posted the .pdf in the Plans and Drawings section as discussed. That way they can reside here and not require an outside link, though that worked well also.
« Reply #12 on: August 01, 2017, 12:10:13 AM »
Tom
Hey Tom,
Sure hope you get to feeling much better soon and can back in the shop.
« Reply #13 on: August 01, 2017, 12:11:48 AM »
Thanks Bill,
This will make it easier for everyone here, appreciate all your help.
