Matthew, looking at your profile info. I assume you are in the Boston area of the USA. it would help to know if you plan on doing metric or imperial work most of the time. Even plans it castings that specify metric or BA threads can offer be converted to imperial and vice versa. The main thing is to invest in quality drills, even though the cost is substantially higher. Personally I have a set of # 1-60 drills, fractional from 1/16- 3/8ths by 1/64 increments, black oxide and jobber length and these work for 99% of what I do though I work in imperial measurements.Bill
* For machines of the size I have, will I quickly run out of room on "jobber" lengths, or should I be mostly ok?
