Author Topic: I did a bad bad thing......  (Read 33334 times)
Re: I did a bad bad thing......
« Reply #150 on: October 21, 2017, 10:35:23 PM »
Nice Dave. Still following along. The little Levin is really coming along well.
Offline Bjorn_B
  • Sweden
« Reply #151 on: October 22, 2017, 07:21:27 AM »
This is good work! Keep it up, I have a small G Boley (size 2) that lacks the slides (amongst other bit and pieces). Been thinking of making my own.. Will keep a very close eye on this thread :happyreader:
« Reply #152 on: October 22, 2017, 12:04:18 PM »
The Boley 2 has a 65 mm center height compared to the 50mm on the Levin,  but I think this slide could certainly handle it as it's a bit "beefy".
You could always scale it up by 65/50 if you wanted to.
« Reply #153 on: October 23, 2017, 12:24:05 AM »
A little more done today....dovetails cut, nut blank made and installed....I need to drill and tap the nut in position....not too bad at all to make
Scraping "SHOULDN"T" be too involved.   it fits nice, and the dovetails were cut all with the same cutter and in 1 set up.   Then should be a good match.
I'll just check them though
« Reply #154 on: October 23, 2017, 12:26:42 AM »
Dave, what will you use for the gib? Brass?
« Reply #155 on: October 23, 2017, 12:33:54 AM »
Probably cast iron
« Reply #156 on: October 23, 2017, 12:43:16 AM »
Nice work Dave!
I'm enjoying this little project.
« Reply #157 on: October 23, 2017, 12:47:28 AM »
Thanks Dave  it's coming along pretty easy.
« Reply #158 on: December 12, 2017, 12:26:55 PM »
Just checking in Dave....any progress to report on the little Levin??
« Reply #159 on: November 27, 2018, 02:54:32 PM »
OK Dave, so its been almost a year, but now that the leg is better and the shop warm, hopefully you can gat back to this little project as well. Any progress on finding/making a cross slide for it?
« Reply #160 on: November 27, 2018, 07:13:49 PM »
Ive started it as is documented, but ive not gotten any further.  I may just cave and buy one off the bay.
« Reply #161 on: February 02, 2019, 02:19:40 AM »
Almost there!.....
« Reply #162 on: February 02, 2019, 02:39:09 AM »
Looks right at home there  :ThumbsUp:
« Reply #163 on: February 02, 2019, 02:40:12 AM »
she's getting there that's for sure!
Got some handles drawn up....should be a easy "help a sister out" job for Samantha Bell.
« Reply #164 on: February 03, 2019, 11:11:21 PM »
Finally!     It is alive!..   im going to change the motor to a small 3 phase and a potentiometer....but its alive    time tmake new ball handles.
