Author Topic: I did a bad bad thing......  (Read 26105 times)
Re: I did a bad bad thing......
« Reply #45 on: August 08, 2017, 02:51:06 AM »
OK   as long as we're going there....was it one of these?
Nope. Try here.
http://norristwins.com/heehaw.htm
As for Lovey (Mrs. Thurston Howell the III)...all I can say is experience, class, and style...well.
And then there's the money.  ;D
Online steamer
« Reply #46 on: August 10, 2017, 01:13:57 AM »
Hmmmm
Online steamer
« Reply #47 on: August 10, 2017, 01:16:19 AM »
OK....back on task.      I got the runner blank.   A M42 HSS drill blank of 0.3125/0.3123 diameter.    It fit PERFECTLY.    On to the next part of the process...
I also got a nice storage box for her.
« Reply #48 on: August 10, 2017, 01:16:41 AM »
Oops, I was thinking that is what she called him, you would think after all those years watching it after school every day my memory would be better.  :lolb:
Online steamer
« Reply #49 on: August 10, 2017, 01:27:56 AM »
Naah.....Not feeling it.     The Levin is far more girl than a rich real estate mogul who just wanted a free trip to Hawaii.
Ms Lovely it is.
Glad we got through that ,,,,,might not sleep again tonight....   8)
Online steamer
« Reply #50 on: August 10, 2017, 01:33:26 AM »
Fits her well.
« Reply #51 on: August 10, 2017, 01:37:44 AM »
We will be needing pictures of all this Dave 😁. In your spare time of course.
Online steamer
« Reply #52 on: August 10, 2017, 01:41:35 AM »
Trying to figure out what motor to drive her with....   I have a 1/6 HP 1725 induction motor...nice and quiet.   I also have a Sherline motor with variable speed....but not so quiet.
Ms "L" doesn't have to work about metal removal rates.......hmmm
In any case there is room for either motor as well as the lathe in box.   Then I'm going to put a tool tray above them for collets, cross slide, draw bar and runners.    Self contained and ready to be used but protected.
« Reply #53 on: August 10, 2017, 01:44:23 AM »
Nice...any progress on the cross slide yet?
Online steamer
« Reply #54 on: August 10, 2017, 01:46:12 AM »
Oh man that be secret Squirrel stuff right there!....
Now I'll have to send Vinny!
 8)
Online steamer
« Reply #55 on: August 10, 2017, 12:05:38 PM »
Anybody got a spare  1/8 or 1/4" or number 32 or 64 Levin 8 mm collet?
hmmmmm?
I'll have a good set with those two and what I have currently
« Reply #56 on: August 10, 2017, 12:31:12 PM »
Cross slide, what cross slide   8). Let me look, don't know about extra collets  :shrug:
Cletus
Offline CHP
  • cheers
« Reply #57 on: August 10, 2017, 02:11:32 PM »
Picked up a few collets, and a storage box for the little girl.
She needs a fitting name!     Cletus!!?
what would be the size of that cross slide???
I think I have one here  :o
12x36 lathe,Seig7x10 lathe, Taig lathe
9x29 Mill, Emco 55 CNC mill.......
« Reply #58 on: August 10, 2017, 03:21:20 PM »
Dave (CHP), the lathes are Levin Model B.
Cletus
Online Dan Rowe
  • Dripping Springs TX USA
« Reply #59 on: August 10, 2017, 03:27:36 PM »
Dave,
As you most likely know anything with Levin stamped on it goes for a premium price. This makes a Levin triple or double slide a bit expensive. The only reason to go with a Levin over a Boley or a Derbyshire of other good slide is the Levin has an extension of the main lead screw. The purpose of the lead screw extension is to use a screw cutting attachment.
http://www.watchtoolsonline.com/Screw-Cutting-Attachment-for-Levin-other-Watchmakers-Lathes-7047.htm
The other feature on a Levin slide that is not on other slides is there is a recess with a pin in the top surface this is for a hand lever. The lead screw can be removed and the hand lever attached for rapid travel.
I have been collecting Levin parts for a few years now. I started with a Levin triple slide that I got at a steamup for cheap. The rest of the lathe has not been cheap.
Dan
ShaylocoDan
