Author Topic: Elmer's #33 Mill Engine - MZT  (Read 17393 times)
Offline mzt
« on: September 21, 2012, 08:39:40 AM »
Another 'move': nothing new till post #9
Marcello
This is a fitting job,
not a production job that can be measured in.
Offline mzt
Re: Elmer's #33 Mill Engine - MZT
« Reply #1 on: September 21, 2012, 08:40:57 AM »
The Floor and Bases
Made them long time ago, no pictures were taken.
Milled them to size from various offcuts taken from the scrap pile, then drilled all the holes using the DRO.
Bevelling will be the last operation,  after checking all parts are fitting OK.
The cylinder
A friend of mine brought me this partially machined con-rod cap from work: the drill obviously wandered and the item had to be discarded. That?s cast-iron of the finest grade!!!  And there?s enough material to make 3 cylinders.
After a quick (so to say) session with the hacksaw I?ve got the blanks to start working on.
1st step:  I secured the material into the vice, suspended on two spacers and a rod through the bore, to mill a face reasonably parallel with the bore axis.
2nd / 3rd step:  (no pictures taken) The recently milled face was put against the fixed jaw of the vice, and the same method as before applied to mill a second face, square to the first and (again) reasonably parallel to the bore.
4th step:  now on the lathe faceplate, making use of the two surfaces at right angle to face one end of the cylinder and machining the bore.
Steps 5, 6, 7, ... n: OK, I messed up!
When I dismounted the cylinder, all would have been OK if only I had not forgotten to make several passes with the boring bar on the final cut, to for the springiness of the tool.  Took a final heavy cut, instead, to improve the finish.
(Yep!  Finish was definitely better on heavy cuts than on shallow ones)
Results were a noticeable taper into the bore, too evident to correct in any way but machining again.
(Stopped taking pictures for a while, at this point).
The cylinder was mounted vertical into the mill vise, checked for trueness and centred with a DTI and then bored to a cylindrical shape with a carbide tipped bar into the boring head. ? Several ?last passes? were not forgotten, in this occasion.
Step n+1:  some more work on the mill to bring the external dimensions of the cylinder to size, taking reference from the bore.  With the material finally squared and brought to size, I drilled all the passages, the holes for the holding screws and milled the slots for the steam.
Step n+2:  after machining a mandrel + cap to bore size, I mounted the cylinder on the lathe spindle to turn round the upper and lower portions.  (the next two pictures show the mandrel  and cylinder I had made while building #29, same principle applies)
Step n+3: the mandrel assembly was then transferred to the rotary table (picture shows the mill ER32 collets holder I used) to be milled and rounded in the central part.
The Heads
Chucked a small brass rod into the lathe, faced and turned it to size.  Zeroed the adjustable  carriage stop and took a light facing cut, then moved the micrometer 9/10mm to the left to machine the portion to fit the cylinder diameter, then parted off the outboard head. (The remaining pip was removed with pliers, file and sandpaper).
The inboard head was made by machining the external part first, then reversed into a collet to make the hidden portion.
Drilling the hole was a slower job: first of all, I set a piece of scrap al. Into the vice, zeroing the DRO roughly in the center. Then I drilled a hole to fit the outer head
Inserted the head (reversed) and drilled the holes at coordinates (the DRO helped a lot into that!)
The outboard head was held through enlarging the hole with the aid of a boring head till it was large enough to accept the head in its ?normal? position. Had some issues regarding the head possibly moving during the drilling operations, so I held it in place using some paper tape.
Was right about the issues, not so about preventing the head from moving: when the centre bit grabbed on the third hole...
Fortunately, the head was not ruined: at that point I drilled the plate through, and used a screw and nut to keep the head  in place. Then drilled a diametrically opposed hole for a second screw.
Here?s a coupla picts of the cylinder, complete with the heads.
The Crosshead Guides
Sawing part of the unneeded material,  I will find some use for that.
Next, I milled the part to size and a decent finish marked it, and finally cut it. Here they?re shown after  the final milling on the parting line.
The Piston shaft won?t line with the guides!
While test fitting the cylinder ,crosshead guides and a temporary piston shaft  on the base, I  had the unpleasant vision of a piston shaft unequally  spaced among the guides, because the two fixing holes on the bottom of the cylinder were misplaced.  Chose the easy way of re-drilling the holes on the base.
First of all, I need to fill the voids: here, i?m machining a 3mm screw from a short rod of gummy al.
Not such a good thread, but hopefully thread locker will aid.
In the background, the base evidencing the two holes I need to move.
Barely visible, the two holes already filled. Now i?m ready for re-drilling them in a more suitable position.
Had to enlarge the coutersinks on the bottm side. Sure, this piece has evidence of poor craftmanship.
But they will be hidden, and no one will ever see them..
Things are much better aligned, now.
Marcello
Offline mzt
« Reply #2 on: September 21, 2012, 08:45:47 AM »
Flywheel
Here?s the blank: a 72mm thick walled steel tubing from the scrapyard.
Turned  on the outside (with no attention to the finish), bored to whatever diameter it came, faced, parted and re-faced on the second side.
A small aluminium plate held in the 3jaws for facing and drilling a hole in it. That?ll be the blank for the flywheel webs, I do not yet know what shape I will make them.
Next, I turned, drilled and reamed a small brass rod to accept the flywheel shaft, to be press fitted into the webs blank.  Got a push fit, not enough secure for my tastes.
I set the hub on a temporary shaft to  knurl  its central part, then wetted it with loctite and repressed into the al.
That should do, will know for sure tomorrow.
Piston and piston rod
Having been forced to let the flywheel aside till the loctite is set, I turned a piston out of the tiniest piece of bronze I had: did not have to remove much material to get it to size.
First of all, i cut and threaded the piston rod ends, then chucked the piston blank in a collet and turned it .5mm oversize. Next, I drilled the tapping and clearance hole for the 3mm shaft, screwed in the rod (with a bit of loctite, as it was still at hand from the previous job), re-chucked the shaft in a 3mm collet and brought the piston to push size.
That should ensure the piston and piston rod are exactly on the same line.
The picture shows the piston and cylinder after the final lapping using very thin polishing compound and oil.
Marcello
Offline mzt
« Reply #3 on: September 21, 2012, 08:46:30 AM »
The Flywheel (continued)
An initial deep (5mm) cut showed no signs of motion among the loctited parts:  rather have them split now than on the final cut, :-)
Roughing cuts: the finish is ugly. Hopefully a round nosed tool when I will get to the sizing cuts will do better.
It did.
After pressing the tyre, I had the (bad) idea of mounting the wheel on a 6mm arbour and spin it in the lathe for a final truing: got chatter, tremendous! Like waves on the sea (in a windy day).
I should have take a picture of it.
Dull tool? Mounted another, same results.
Speed up? Slow down? Skin cuts? Deep? ....?  ...?
Answer was always CHATTER! CHATTER! CHATTER! !!!
Then, it occurred to me the wheel was mounted on a 6mm silver steel arbour... and if it were due to springiness on the arbour ?
When I mounted the wheel  hub into a 19mm collet, however short the grip was, the chatter disappeared.
Marcello
Offline mzt
« Reply #4 on: September 21, 2012, 08:46:57 AM »
The Bearings
A bit of progress on this long forgotten project: last Saturday I got around making the bearings;  while I  was at them, I decided to make a few, just in case I will get interested into building another engine from the book. <G>
Started with squaring a block of aluminium, then centring the cutter and milling the sides to depth; when it came to rounding the edges I decided to make an experiment into grinding a cutter right for the job.
Started with a 10mm 2 fluted end mill who had seen too many resharpenings (only a few mm of flutes were left) and ground away one of them [==> single cutter, so I won?t have to make two cutting edges alike].
A few minutes of hand grinding on the bench wheel  (and many more toying myself with diamond files and oil stones)  gave this result
Had a little more shop time to spend (not enough to complete the bearings) so I decided to use it making some of the missing parts for the crosshead guides, hacksawing and polishing them from a 3mm brass plate.
It was already late at night: I left the drilling for the next day...
..being well aware the next morning I?d have picked up another project.
Marcello
Offline mzt
« Reply #5 on: September 21, 2012, 08:47:22 AM »
Small works on Bearings, Base and Lugs
I?m only working on this engine at random intervals, whenever I?ve no time or interest into working on parts
for other engines and no new project gets in the way.
Gotta push this one too, if I want to bring it to an end.
Having recently shaped a long bearing block, I cut two portions of it, gave them a decent finish using a
flycutter and sized one to the correct height.
The taller one is already too short, I knew:  will look for some way of putting a bit of metal where it should be.
A second look at the slots I had cut into the base to accept the lugs revealed all the damages I had done while
trying to bring them to a better finish through improper hand use of machine tools & desktop accessories.
Had to cut them once more in the mill, deeper and larger.
Next I roughed the lugs, from some 10mm gummy square, still longer and thicker than needed.
Will have to bring the base to the desired finish before fitting them in place, should I opt for a permanent mount.
Marcello
Offline mzt
« Reply #6 on: September 21, 2012, 08:47:46 AM »
Reaming a bevel
I temporarily mounted the sub-base to the floor, set them flat into the vice on parallels and chucked the
largest taper reamer I could find into the ?tools purchased by weight? drawer.
I had more concerns about ruining the workpiece than about the reamer: that one, together with most of the others,
has been laying there for years, unused.  I?ve never been in need to ream a hole to an unknown taper, and
I don?t think I will be likely to face such a task in the near future.
In the end, I got the job done in seconds, and the reamer suffered no visible harm.
The bevel is shallow, but clearly noticeable.  A bit of sandpaper work on the plate should bring the item to a decent finish.
Before dismounting the sub-base, I drilled a couple (three, to be exact. But the third one I?m trying to forget..)
of extra holes  through both the items using a 2.9mm bit. That made holes exactly the size of a 3mm bit shank:
they should aid re-aligning the base with the floor on subsequent mountings and dismountings.
Marcello
Offline mzt
« Reply #7 on: September 21, 2012, 08:48:13 AM »
Small bevelling progress, no pics.
Spent (quite) a few minutes reaming a bevel on the top base using a different reamer, one which was slightly more tapered, from the same scrap pile.
Gotta buy myself a tilting vice, someday.
I made use of the aligning holes I had put on the floor and base to have them aligned, then placed three washers between the assembly and
the top base, to gain some working clearance.
At the end of the job, I decided to deepen the aligning holes into the top base: cannot say how, I managed to clog a 2.9mm drill bit into aluminium,
while deepening the second hole to an extra 5mm.  Unusual clog, btw: the bit could turn, but no way I could get it out.
Got it back again, after dismounting, but I don?t think them holes will be any good for the purpose I had put them in.
Had to swallow it: it was not going to be a good machining day.
Rather shut off the machines and look for some hand work: removing tool marks and polishing the bases did, though it lasted much longer
than the ?bit of work? I had estimated.
And aint close to the end, yet.
Marcello
Online steamer
« Reply #8 on: September 21, 2012, 09:08:50 AM »
You've been very busy Marcello!
 :NotWorthy: :NotWorthy: :NotWorthy:
« Reply #9 on: September 21, 2012, 09:32:41 AM »
Wow, hasn't he!
I like your reuse of that original damaged crank cap :ThumbsUp: Waste not, want, not.
And looking at your tools and set ups: I must :wallbang: :wallbang: make myself a decent set of clamps for my vice, yours are so simple! If I made a set, it would make life so much easier.
Forgive me for my ignorance: any chance of an outline drawing of what you are building? I know that many members from the other side of the pond know all about these Elmer designs but they are all new to me.
Offline mzt
« Reply #10 on: September 21, 2012, 09:51:23 AM »
Dave,
I cannot spend all my shop time making tools and fixtures, gotta work on engines at times!!
Jo,
Elemer's Verbourgh engines were recently removed on request of the copyright owner from the PD (the whole book was available through the Elmers_Egines groups, on Yahoo).
I suppose the john-tom www.john-tom.com site still has them, I have not checked back.  (In the last couple of minutes)
Marcello
« Reply #11 on: September 21, 2012, 10:13:59 AM »
Offline mzt
« Reply #12 on: September 21, 2012, 10:31:33 AM »
Jo,
as for the clamps, it took about six years for me to get around making them.
Then, made the four of them in half an hour or so: just chucked pieces of square bar in the lathe, rounded one end to 8mm, drilled and coutersunk the cross holes for the screws.
Marcello
Offline mzt
« Reply #13 on: September 21, 2012, 10:43:24 AM »
Anchor lugs.
They were cut to a tight fit with the slots in the base long time ago, only needing some rounding of the ends and being brought to the correct thickness.
Some fancy setup, but it worked with no shake however tall it was.
Lugs in place
Marcello
Offline NickG
« Reply #14 on: September 21, 2012, 06:21:42 PM »
That's looking great Marcello, I really need to stop looking on here at all these great projects, it's making me want to do more and more!
Nick
