I have found an airship engine to have a fondle of Jo
Which one ?? Engine, that is. Thought the Zeppelin Maybach were 6-potters ?? IIRC the ones at Freidrichshaven were ( Zepp. Museum, well worth a loooooong look )
The nearest MOD number is not one of the cheap ones the Chinese do... Which reminds me Sexy has a couple of small MOD gear cutters Jo
Can you not play about with the tooth numbers to make them a common MOD size, so long as the PCD is about right they should work fineWhat about this 24T 0.5 MOD which is not far off a 22T 48DPhttp://www.ebay.co.uk/itm/4-5mm-Bore-24T-0-5-Modulus-Metal-Umbrella-Tooth-90-Pairing-Bevel-Gear-24-Teeth-/262649809294
