Author Topic: The "Little Pearl" Single Cylinder Marine Engine  (Read 75652 times)
Offline Flyboy Jim
  • Independence, Oregon
Re: The "Little Pearl" Single Cylinder Marine Engine
« Reply #285 on: November 20, 2017, 03:29:29 AM »
Bill..... you started this thread around the time I took my "time-out", so am just starting to get caught up (I'm on page 5). I always enjoy your build threads and seeing how you machine parts on your Sherlines .................and this thread is no exception!
Sherline 4400 Lathe
Sherline 5400 Mill
Offline Flyboy Jim
« Reply #286 on: December 01, 2017, 03:21:32 PM »
OK Bill, I'm all caught up now on this thread. Well done.  :ThumbsUp:  Even though it's more work.........it seems really rewarding to carve those parts out of cast bronze. I know I've enjoyed doing that on my P & W build.
Anyway............thanks for waiting for me to get caught up..............you can carry on now!    :) :cheers:
Sherline 4400 Lathe
Sherline 5400 Mill
« Reply #287 on: December 01, 2017, 03:44:51 PM »
Thanks Jim!  Shop time has been scarce lately but hope to find a little time over the weekend.
« Reply #288 on: December 03, 2017, 07:54:59 PM »
This weekend I have been playing around with one of the two main bearing cap castings. As you will see the casting is a lot bigger than the final part requires so it was slow going on the sherline but still very do-able. This first photo shows one cap machined down to its final overall size compares to the original casting. Once I got the ends and sides milled down to their final size (photo 2) I flycut the bottom surface to mate with the base eventually (photo 3). With that done, back to the mill to spotface and drill the four mounting hole (photo 4). Photo 5 again shows the finished part in relation to the original casting, and photos 6 & 7 show the finished cap. The final boring will not be done for the crank bearings until the caps are installed on the base.  The top of the caps will be left as is to add some of that "castingness" to the overall look :)
« Reply #289 on: December 03, 2017, 08:04:17 PM »
Looking good!
Are you going to be using hex head bolts or studs/nuts in the final engine? If so, are those flats around the bolt holes large enough for the hex?
« Reply #290 on: December 03, 2017, 08:19:20 PM »
Undecided yet Chris, but leaning towards hex bolts. The threads are 10-32 in the  base, the spotfaces were done with a 5/16" end mill. I may try making a bolt out of 1/4" hex brass to see what it looks like. Can always use 10-32 SHCS's in stainless as well which would fit with a marine engine. The SHCS shown is just a 10-32 from my sherline hardware. Granted hex cap screws would look better.
« Last Edit: December 03, 2017, 09:23:37 PM by b.lindsey »
Offline NickG
« Reply #291 on: December 03, 2017, 09:14:51 PM »
Looking good Bill, lot of castingness left with the spot facing. Looks the part.
« Reply #292 on: December 03, 2017, 09:31:19 PM »
Thanks Nick. The vase will be machined all over so something needed a bit of casting texture. The pedestal should be another source of said "castingness" but have yet to do anything on that front.
Chris, I turned up a doomed hex cap screw out of 1/4" brass and I think that will work well and fits the spot faces well and there is even room to tighten them with a hex driver. I'll take a couple of pictures later and post them. Glad you asked the question as these can all be turned up even in little bits of shop time. Just need to check the drawings and see what length they need to be now.
« Last Edit: December 03, 2017, 10:16:39 PM by b.lindsey »
« Reply #293 on: December 03, 2017, 10:15:56 PM »
Here is a dome head hex cap screw turned from 1/4" brass hex stock. I think given that there are 4 screws holding the cap on and that it only has to hold the bearing in place, I think this will do. Picture one shows the shoulder of the screw and photo two shows it in place in the bearing cap.
« Reply #294 on: December 03, 2017, 10:17:22 PM »
Those look great! And checking that the driver or wrench will fit is always something I forget to do!
« Reply #295 on: December 03, 2017, 10:18:11 PM »
I guess the decision is made then Chris :)
« Reply #296 on: December 03, 2017, 10:24:30 PM »
I like the use of the reduced head size. That makes it all fit nicely.
 :ThumbsUp:
« Reply #297 on: December 03, 2017, 10:37:21 PM »
Thanks Pete, it is a bit smaller than the OD of a 10-32 SHCS but close enough to look "right" I think even so.
« Reply #298 on: December 04, 2017, 12:25:44 AM »
You get my vote Bill, the dome head bolt looks perfect!
Nice progress.
Offline 90LX_Notch
    • YouTube Channel
« Reply #299 on: December 04, 2017, 01:29:24 AM »
Yes, the domed head looks great.  Great progress as usual Bill
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
