Author Topic: R & B engine  (Read 1604 times)
Offline Quadra
  • Cambridge UK
R & B engine
« on: June 19, 2017, 02:53:06 PM »
This is my R & B I built some years ago and failed to get to run. After completing another project a couple of years later, I made a determined effort to get it to fire up. The valve timing, ignition and compression were all OK so it must be the carb. that's the problem. The engine is fueled with propane. To cut a long story short it turned out to be the the carbs. air inlet was far to large. So a suitable restricter made and fitted. Priming the KN demand valve and with a few swings of the starting handle, the engine popped into life.
<a href="https://www.youtube.com/watch?v=Qmr7otUb3-s" target="_blank">http://www.youtube.com/watch?v=Qmr7otUb3-s</a>
The engine though still needs some tinkering but it runs.
(Running this type of engine on pneumatic tyres probably not a good idea, a bit bouncey)
Re: R & B engine
« Reply #1 on: June 19, 2017, 04:41:44 PM »
Beautiful engine John, and you have it running very well from what I see.  Glad you came back around to it and found the issue in the carb. It sounds as good as it looks too!!!
Re: R & B engine
« Reply #2 on: June 19, 2017, 05:13:41 PM »
8)
I still have not got my one to run  :ShakeHead: Any more details on the fix would be appreciated.
Re: R & B engine
« Reply #3 on: June 19, 2017, 05:18:37 PM »
Looks good in red, a definate improvement on the usual dull green, running too :)
