Author Topic: 'ello .. 'ello .. 'ello Wot 'Ave We 'Ere Then??  (Read 1901 times)
Offline Bluechip
  • Derbyshire
« on: June 17, 2017, 09:05:29 AM »
Could this be 2 bits of 200mm x 200mm  x 10mm ???
Alas, 'tis plate. Not castings ...  :'(
Still, ne'er mind Eh?
Someone,somewhere will surely find a use for it.
Re: 'ello .. 'ello .. 'ello Wot 'Ave We 'Ere Then??
« Reply #1 on: June 17, 2017, 09:23:59 AM »
 :thinking:
I could find a use for those  ;D
« Reply #2 on: June 17, 2017, 10:17:45 AM »
Suit the bottom of your Otto they would Jo even though you usually prefer your steel stock with that brown coating, shame mine is already done.
Infact I may not use mine so you could have one ready done if you are a good girl.
« Reply #3 on: June 17, 2017, 06:36:21 PM »
That's no good for me JB the original patent engine doesn't have that radi around the top  :ShakeHead:
Now Dave's bits of metal might :naughty: then all I need is a few Jaffas or better still some chocolate Truffles and I might not be a good girl :cartwheel:
« Reply #4 on: June 17, 2017, 07:42:04 PM »
I think the Lenaz one is a bit bigger than the patent so you could probably just mill the edges of the octagon down to remove the moulding and be about right for size, at least it has the correct six holes in it as per patent and later production engines :)
Database Error
Back
