Author Topic: My tiny "Tiny" build  (Read 3936 times)
Offline Marinus
  • Limpopo, South Africa
« on: June 16, 2017, 07:30:25 PM »
Hi all,
I wanted to build a small IC engine, small enough to put my skills to the test, asked around on HMEM and got to PUTPUTMAN aka Arv's Tiny IC. I know what you all must think now, "another one" right? :facepalm: Well this one's different being my first IC engine and it'll be in metric. :cartwheel:
Okay so almost a week ago I started cutting away at my first part, which was unsuccessful. Well I couldn't leave the workshop without the satisfaction of holding a part I just made, so made the fuel tank first.
The next day I made the flywheels and started with the head. Now as all of you "Tiny" enthusiast may know, is that the original plans by Arv, shows the spark plug hole at an angle of 10 deg from the front and 10 deg from the left. Tried figuring out how to hold it in the mill, as we don't have any fancy swivel vices... but what we have is a 3D printer. So I drew up some holders to hold the head at the correct angle and printed it. It worked great, and made quick work of something that would've taken me a while.
I then turned to the spark plug, which is another reason why it's so special.. because it was made from bones :o Okay well, we don't have any corian or drylin, then I saw a piece of bone that was left over from the gun butstock my dad had to make for someone, so I figured that I might as well give it a try. Well the spark plug works, but I don't know for how long .
The cylinder was made from some steel bar and drilled and bored to size and finally lapped. Piston was fairly quick to make and fitted a Buna-N o-ring, that I know I should replace.
I made the valve next (only one at the moment) , easier than I thought it would be. I deviated from the plans when I made the valve, I made it thinner at the valve bottom to allow a bit more flow. The valve keeper was fairly easy as well, I just lost 3 of them, by sneezing, by dropping it in the swarf and the other one I just can't remember where I had put it. :shrug:
The crankshaft was the part that had me worried, the first one was a complete stuff up, but the second one came out okay I think. Took a bar of steel just over 20mm and center drilled both sides, marked out 0.250" from the center on both sides, making sure that they are both square, and center drilled them as well. I used a center held in the chuck and the live center at the toolpost and wanted to use a lathe dog to machine the crankshaft, but the one we have just won't fit, so I just went ahead without the dog. Surprisingly it worked, but didn't want to hold when I wanted to machine the crank pin. So I used the hot glue gun, and after 5 or 6 tries it finally held on. After the shafts have been machined to the right diameter I took it to the mill and machined the counterweight.
Here's all of the bits together with 1 Metical.
So tomorrow I'll have a go at the conrod, while I wait for my cutter to arrive to machine the crank case.
Thanks for looking in :)
Kind regards
Marinus Kruger
Re: My tiny "Tiny" build
« Reply #1 on: June 16, 2017, 07:35:25 PM »
Very nice work!
I had to look up the Metical, found it is 21mm diameter, those parts are quite tiny!
Offline Marinus
« Reply #2 on: June 16, 2017, 07:45:26 PM »
Thank you Crueby. I've only just seen that the pics are rotated. Sorry about that, but photobucket doesn't want to rotate it.
Kind regards
Marinus Kruger
« Reply #3 on: June 16, 2017, 07:48:36 PM »
I had not even noticed!
In photobucket, if you click on the image to view it full size, then click on the icon in the upper right that looks like a gear, there are rotate options in the menu that comes up.
« Reply #4 on: June 16, 2017, 08:04:21 PM »
You are off to a great start Marinus, I will be following along with keen interest.  :popcorn:
Offline 90LX_Notch
    • YouTube Channel
« Reply #5 on: June 17, 2017, 12:03:34 AM »
Wow Marinus that is an impressive amount of parts in a week.  You must work at the speed of light.  Great start.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
« Reply #6 on: June 17, 2017, 02:07:11 PM »
Is it possible that You and Chris are sharing elves from the same union ?
Marinus nice start of this project and these parts are really tiny.
« Reply #7 on: June 17, 2017, 06:32:17 PM »
I published my shop gnome to shop elf cookie recipe a while back, maybe he is using it!!  :lolb:
Offline Marinus
« Reply #8 on: June 17, 2017, 07:33:25 PM »
Thank you all ;D
I wish!! I think mine might be from Russia, still can't get my head around to understand a word they are saying.. oh and they are sober twice a week :facepalm:
I didn't know about a recipe.. but now that gives my quite an idea :thinking:
« Last Edit: June 17, 2017, 07:37:38 PM by Marinus »
Kind regards
Marinus Kruger
Offline Marinus
« Reply #9 on: June 20, 2017, 07:45:45 PM »
Hi all,
I didn't make a lot of progress, because I had to study for exams.
The connecting rod has been made, took a few tries to get it right. It was machined from aluminium. The blank was cut out and then it was squared up in the mill and the recess cut for the two piece bearing at the big end. I then drilled and tapped the holes and mounted the piece of previous machined split bearing half and machined it to final size. The holes were then drilled and the big end was reamed. A "pin" was turned from a piece of steel in the lathe and the rod's small end was glued on so that I could machine the round end of the con rod. It was then heated up to release the glue and turned around to machine the other end. I then just used a file to round of the rest of the rod. I then used some fine wet and dry sanding paper to get rid of all the edges and brushed with a wire brush.
I then went on to make a "non functional" part, the exhaust. I used George's (gbritnell) design, but made it a bit smaller. First the top part was machined and parted of over size and then I machined the body. I made it a light press fit and silver soldered it together. I then machined the part in the lathe and parted off. I then drilled the holes (14 in a row instead of 12) without using an indexer, just took a pair of dividers and marked out the position of the holes.
My cutters finally arrived, so next up will be the crankcase.
It's a "throw away" 3 flute long series end mill from Kennedy.
Thanks for looking in.
Marinus
Kind regards
Marinus Kruger
« Reply #10 on: June 20, 2017, 09:33:41 PM »
Very nice and looking good.
« Reply #11 on: June 20, 2017, 09:50:14 PM »
Nice work!
I hadn't noticed before that the con rod end bolts on from the side, I like that way of doing it. Is that common on certain types of engines?
« Reply #12 on: June 21, 2017, 02:00:34 AM »
Marinus, just curious....what do you mean by "throw away" end mill?
Offline 90LX_Notch
    • YouTube Channel
« Reply #13 on: June 21, 2017, 04:19:54 AM »
You are rolling right along Marinus.  Looks good.
-Bob
Proud Member of MEM
Offline Marinus
« Reply #14 on: June 21, 2017, 06:58:59 AM »
Thank you all.
Arv designed it horizontally because of the tight spaces that was involved. He mentions that this way it just about touches the base of the frame.
I've seen a crank journal mounted at 45 deg but not horizontal like this one.
It is basically just an end mill, or slot drill , that has a Weldon shank. These throwaway cutters from Kennedy range from 1mm to 10mm diameter. So it is usually used for CNC milling or routing and so on where small cutters are usually used. I didn't know this, only just after I asked on HMEM that I was explained what it was.
Kind regards
Marinus Kruger
